[gdal-dev] Maintainers and PSC: please reject bulk PRs from fake GitHub personas, correct or not
Sean Gillies
sean.gillies at gmail.com
Thu Nov 12 17:01:19 PST 2026
Dan,
According to AgentScan, https://agentscan.tools/user/alepacheco, is a legit
GitHub user since 2014. My own nose agrees. I don't see any sign of them
spamming projects. On the other hand,
https://agentscan.tools/user/spaceoceancorp from
https://github.com/OSGeo/gdal/issues/15515 is very much automated and is
spamming projects.
I don't think you need to judge their motives at all. Or look into
their souls. Pattern matching is good enough.
How exactly does closing a PR from a fake GitHub persona hurt GDAL's
credibility? Closing the PR doesn't mean that you have to forget it. It's
still tracked on GitHub. But it does deny the spammer the reward it is
looking for. And you won't have to spend time reading and evaluating a
mid-grade PR. On the other hand, merging PRs from rando spammers causes
actual harm to the project. It rewards a bad actor and disincentivizes
earnest and honest contributors from working on bugs.
There may be legitimate GDAL users with tokens to burn that might want to
follow up on the closed PRs and take proper ownership of them. Maybe give
them a chance. I think it's also 100% fine to take those commits and amend
them with your own name if you think they are valuable enough. The
"authors" won't even notice that you did so. Their agents are spitting this
stuff out and they're moving on to fresh marks.
Yours,
On Thu, Nov 12, 2026 at 5:12 AM Daniel Baston <dbaston at gmail.com> wrote:
> Sean,
> I've had several such PRs lately on GEOS [1], so it's a good example. All
> of them identified real issues. Some of the fixes were fine to apply as-is.
> In other cases I kept the tests from the PR and wrote my own fix. Since I
> doubted that human was strongly invested in them, I didn't worry about
> back-and-forth, I just took what I wanted and moved on. Nothing rose to the
> scale where copyright would have been a concern, and in any case an AI
> policy like GDAL's would block such contributions. Of course I would have
> preferred to see fixes from a motivated human contributor who was deeply
> invested in the geospatial field, but that's not what I got.
> The way I read your proposal, you're suggesting for each pull request I
> first try to judge the submitter's motives. Are they doing some sort of
> karma farming? If so, I must then either:
> (a) close the PR and forget it, even if I think it fixes a real issue
> (b) close the PR and write a fix myself
> Because I believe (a) would harm GDAL's credibility and (b) only increases
> the burden on the project's maintainers, I would not be supportive of such
> a policy.
> Dan
> [1] https://github.com/libgeos/geos/pulls?q=is%3Apr+author%3Aalepacheco
> On Wed, Nov 11, 2026 at 1:54 PM Sean Gillies via gdal-dev <
> gdal-dev at lists.osgeo.org> wrote:
>> Hello,
>> It's been a while since I've posted here. I hope you're doing well in a
>> weird time.
>> Today I saw an adjacent FOSS4G project merge a PR by
>> https://github.com/KennyMcSimpson. I encourage you to browse to the
>> profile of this entirely phony person and notice that "they" made 122 PRs
>> in 96 projects in one October day.
>> https://github.com/Tyagiquamar is a contributor to GEOS. 190 PRs to 92
>> projects in one November day.
>> This pattern will be coming to GDAL soon. Please reject PRs from such
>> sources. Accepting makes a mockery of open source, rewards bad actors,
>> erodes trust in a project, and I believe it accelerates the downfall of
>> GDAL.
>> I'm not saying don't use AI yourself. I'm only saying don't let obviously
>> fake personas commit to GDAL. It would be better for GDAL project
>> maintainers to do this kind of thing themselves if they feel it is
>> important and necessary.
>> I'd love to see a sign that the PSC recognizes that this is a problem in
>> the FOSS4G and implore you to adopt a policy against accepting these fake
>> contributions. They're not hard to identify, it only takes a click or two
>> and a little scrolling.
>> Yours,
Sean Gillies
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20261112/741baf02/attachment-0001.htm>
