[gdal-dev] Motion: Nominate Dan Baston as PSC Chair
Rahkonen Jukka
jukka.rahkonen at maanmittauslaitos.fi
Wed Nov 18 10:22:06 PST 2026
I have not received the original mail, but I would have answered +1.
-Jukka Rahkonen-
________________________________________
Lähettäjä: gdal-dev <gdal-dev-bounces at lists.osgeo.org> käyttäjän Howard Butler via gdal-dev <gdal-dev at lists.osgeo.org> puolesta
Lähetetty: Keskiviikko 18. marraskuuta 2026 19.03
Vastaanottaja: gdal dev <gdal-dev at lists.osgeo.org>
Aihe: Re: [gdal-dev] Motion: Nominate Dan Baston as PSC Chair
HUOM! Ulkoinen lähettäjä. Älä avaa linkkejä tai liitteitä, ellet tunnista lähettäjää. OBS! Extern avsändare. Öppna inte länkar eller bilagor om du inte känner igen avsändaren. NOTE! External sender. Do not open links or attachments unless you recognize the sender. Declaring this motion passed with +1s from Howard, Norman, KurtS, FrankW, DanielM, JavierJS, and MikeS.On Nov 16, 2026, at 11:19 AM, Norman Barker via gdal-dev <gdal-dev at lists.osgeo.org> wrote:+1 NormanOn Mon, Nov 16, 2026 at 11:14 AM Kurt Schwehr via gdal-dev <gdal-dev at lists.osgeo.org> wrote:+1 KurtSOn Mon, Nov 16, 2026 at 5:25 AM Howard Butler via gdal-dev <gdal-dev at lists.osgeo.org> wrote:All,I would like to nominate Dan Baston as the GDAL PSC Chair. Dan has been a consistent contributor to GDAL over the years, and more recently he has been working as a maintainer in the project with the support of NASA that his company ISciences obtained it beginning in 2022. Dan is a core contributor for the GEOS project he has been active in that community for more than a decade.No single person is going to match Even's activity in these projects going forward. We all took that for granted, but Dan is an excellent candidate to provide project leadership that can help the project move forward as a community to adjust to its sloppy new reality. /me starts with a +1Howard_______________________________________________gdal-dev mailing listgdal-dev at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/gdal-dev_______________________________________________gdal-dev mailing listgdal-dev at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/gdal-dev_______________________________________________gdal-dev mailing listgdal-dev at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/gdal-dev
