[gdal-dev] Can c++ types be used directly from the SWIG interfaces?
Even Rouault even.rouault at spatialys.com
Tue Sep 1 11:02:08 PDT 2026
Michael,
This is likely a design decision from 20 years ago when the "new"
bindings have been added. I wasn't involved, but I can imagine at least
2 reasons to prefer binding C functions rather than C++ classes:
- make sure that the bindings generated against GDAL X still run against
libgdal Y where Y >= X without being rebuilt, since the C ABI is
backwards compatible. But that doesn't seem to be a very
realistic/common scenario
- avoid exposing to SWIG things that haven't been considered stable
enough to be exposed to C
Maybe other GDAL users, such as people doing Rust or R bindings, could
give us some hints if they'd be interested in binding the
GDALGeoTransform class to their language. If so, making C bindings would
serve everybody.
Even
Le 31/08/2026 à 21:50, Michael via gdal-dev a écrit :
> I want to expose the GDALGeoTransform class. It doesn't have a C
> struct representation (like OGREnvelope) or an opaque C handle type. I
> could add C interfaces to GDALGeoTransfor, but that seems absurd since
> GDALGeoTransfor is mostly a C++ wrapper of the C routines.
> However, using the GDALGeoTransfor class directly from the SWIG
> interfaces works surprisingly well (See below). What doesn't work is
> the 'Apply' overloads which accept a `GDALRasterWindow` type, because
> SWIG can't include gdal_rasterband.h while CPL_SUPRESS_CPLUSPLUS is
> defined.
> So my questions are: can I use the GDALGeoTransfor c++ class directly
> from SWIG and, if not, why?
> #include "gdal_geotransform.h"
> class GDALGeoTransform {
> private:
>   const double *data() const;
>   ~GDALGeoTransform();
> public:
> %mutable;
>   GDALGeoTransform();
>   GDALGeoTransform(const double coeffs[6]);
>   GDALGeoTransform(double xorigIn, double xscaleIn, double xrotIn,
> double yorigIn, double yrotIn, double yscaleIn);
>   void Rescale(double dfXRatio, double dfYRatio);
> %immutable;
>   void Apply(double dfPixel, double dfLine, double *pdfGeoX, double
> *pdfGeoY) const;
>   bool GetInverse(GDALGeoTransform &inverse) const;
>   bool IsAxisAligned() const;
> Michael Bucari
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
LLMs contribute to global warming and brain rot.
Let's guillotine them! "Ah ! ça ira, ça ira, ça ira !"
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20260901/766d042f/attachment.htm>
