[gdal-dev] DMARC/DKIM failure on 2026 GDAL Sponsorship Program Funding Appeal
Daniel Evans
daniel.fred.evans at gmail.com
Fri Sep 18 06:35:52 PDT 2026
Hi Howard, and any mail admins who may be on the list,
For your awareness, Howard's email I'm replying to came through with
failing DKIM and DMARC tests, which may have been somewhat detrimental to
getting it through potwntial sponsors' mail servers.
I think this has come up before and it's been a struggle to configure the
mailing list to avoid issues - this is the first time I've seen it for a
while.
Happy to send through the received email and headers if helpful. The
specific complaint is:
Authentication-Results: mx.google.com; dkim=neutral (body hash did not
verify) header.i=@lists.osgeo.org header.s=mail header.b=HY85cgIe;
spf=pass (google.com: domain of
srs0=uqsd=hg=lists.osgeo.org=gdal-dev-bounces at osgeo.org designates
140.211.15.13 as permitted sender)
smtp.mailfrom="SRS0=UQsD=HG=lists.osgeo.org=gdal-dev-bounces at osgeo.org";
dmarc=fail (p=REJECT sp=REJECT dis=QUARANTINE) header.from=osgeo.org
Cheers,
Daniel
On Mon, 14 Sept 2026 at 21:11, Howard Butler via gdal-dev <
gdal-dev at lists.osgeo.org> wrote:
> Hello,
> It is the time of the year when the GDAL Sponsorship Program (GSP) sends
> renewal invoices and attempts to attract new contributors to financially
> support the project. This year, I am writing with an update on what GSP
> made possible for the project over the year. Sponsorship pools resources
> for work that no single organization could easily fund alone, and it
> supports the project-wide work that keeps GDAL fast, reliable, reviewable,
> secure, and ready for contributors. Releases, code review, bug triage,
> infrastructure maintenance, and long-term modernization are things GSP
> supports that every GDAL user benefits from.
> Since its founding, the GSP has been a key driver of operational activity
> in the project. From September 1, 2025 through August 31, 2026, GDAL
> shipped two major releases: 3.12.0 "Chicoutimi" and 3.13.0 "Iowa City",
> along with nine bug fix releases on nearly a two month cadence. GDAL 3.12
> built on the new `gdal` command line interface and added mixed
> raster/vector pipelines, nested pipelines, a `tee` step, and dynamically
> generated Python `gdal.alg` bindings. Other work included raster band
> algebra, VRT pixel-function improvements, release automation, Docker
> attestation, and security fixes. GDAL 3.13 continued that thread with new
> vector commands, dataset checks, COG and GeoPackage validation, support for
> external commands in pipelines, Zarr V3 improvements, COG random-write
> creation, new E57 and CPHD drivers, S102/S104/S111 write support, NITF
> CADRG writing, and INTERLIS 2.4 support. Even Rouault has reported more
> than 590 PRs, tickets, release tasks, reviews, and maintenance items a
> s part of his activity within the GSP for the past year. He has been
> responsible for all release work, repeated PROJ EPSG update handling,
> libtiff and other dependency security remediation, command-line interface
> improvements, Zarr, GeoParquet, VRT and raster-expressions, VSI
> maintenance, driver review, and drafting the GDAL AI/LLM policy.
> Thank you to the organizations who have publicly supported the project
> https://gdal.org/en/latest/sponsors/index.html . Without these resources,
> the project would be struggling to keep up. Unfortunately the funding base
> for the GSP program has been eroding in the past year+, and two gold
> sponsors who stopped supporting the project represent $100k of lost
> support. This matters because the GSP has become the way GDAL pays for work
> that otherwise waits too long. The new command-line interface did not
> appear in one release. The same is true for security hardening, dependency
> updates, Python usability, documentation, cloud storage support, and
> release infrastructure. These threads have run across the whole life of the
> program, and they need renewed financial support through the GDAL
> Sponsorship Program to continue their pace and precision.
> If GDAL is part of your organization's platform, product, data pipeline,
> research workflow, or customer deliverable, know the GSP is the most direct
> way to help keep that foundation healthy besides directly contributing time
> and development resources. If your organization is currently a sponsor,
> thank you, and I hope you can renew again this year. If it isn't, please
> reach out if there is anything we can do to help you make the case to your
> organization's leadership. Renewing or joining as a sponsor helps GDAL keep
> shipping reliable releases, reviewing contributions, maintaining critical
> infrastructure, and addressing the maintenance work that future feature
> development depends on.
> Thanks,
> Howard
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20260918/91f1e213/attachment-0001.htm>
