[geomoose-psc] Last piece of Incubation requirements.
    James Klassen
    klassen.js at gmail.com
    Wed Feb 13 21:23:38 PST 2013
The following makes no sense to me at all.
Copyright (c) 2013, **<YourName> (<YourCompanyName>) (public domain)*
On Wed, Feb 13, 2013 at 3:32 PM, Basques, Bob (CI-StPaul) <
bob.basques at ci.stpaul.mn.us> wrote:
>  All,****
> With Jody and Eli’s help on assembly, here is what we have for the last
> piece of the incubation puzzle to address.  What follows are a couple of
> documenting changes to the GeoMoose site that will describe more fully how
> code is contributed to the GeoMoose project.  While I believe these changes
> could go directly into the two pages referenced.  The second one could also
> be made into separately linked example page as well.****
> I tried to leave the door open to keeping it simple and still flexible.***
> For your review.  There are two pages edits described below.  Please vote
> yay/nay, and I’ll start a trac item once it’s passed.****
> On this page: http://www.geomoose.org/developer/contribute.html****
> Add a point number 6.), to read:****
> 6. Code contributed to the GeoMoose Project (Core codebase) will be
> distributed under the GeoMoose License<http://www.geomoose.org/info/license.html?highlight=license>.
> Other contributed code should be documented as per the developer standards<http://www.geomoose.org/developer/standards.html>
> And****
> On this page: http://www.geomoose.org/developer/standards.html****
> Add a point number 7.), to read:****
> 7. Any contributed code should contain a code source comment block in each
> file header indicating the author (that is you and your employer if you are
> working on company time), date of contribution and any conflicting
> licensing restrictions that are not already covered by the GeoMoose
> License <http://www.geomoose.org/info/license.html?highlight=license>.
> All unusual situations need to be discussed and/or documented on the
> project mail list and/or in the project TRAC system.****
> Here are some example comment blocks for code contributors:****
> If you donated a file to the GeoMoose project, using an MIT license, the
> comment block would include:****
> *Copyright (c) 2013, **<YourName> (<YourCompanyName>)***
> *Permission is hereby granted, free of charge, to any person obtaining a
> copy of this software and associated documentation files (the “Software”),
> to deal in the Software without restriction, including without limitation
> the rights to use, copy, modify, merge, publish, **distribute, sublicense,
> * *and**/or sell copies of the Software, and to permit persons to whom
> the Software is furnished to do so, subject to the following conditions:**
> *The above copyright notice and this permission notice shall be included
> in all copies or substantial portions of the Software.*****
> *THE SOFTWARE IS PROVIDED “AS IS”, WITHOUT WARRANTY OF ANY KIND, EXPRESS
> OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
> FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
> AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
> LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
> FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
> DEALINGS IN THE SOFTWARE.*****
> The accepted project code would be distributed as:****
> *Copyright (c) 2013 Dan "Ducky" Little & Geomoose.org*****
> the rights to use, copy, modify, merge, publish, distribute, *sublicense*,
> and/or sell copies of the Software, and to permit persons to whom the
> Software is furnished to do so, subject to the following conditions:*****
> You could donate it under a BSD, public domain, MIT (see here<http://www.dwheeler.com/essays/floss-license-slide.html>)
> which would result in:****
> *Copyright (c) 2013, **<YourName> (<YourCompanyName>) (public domain)*****
> geomoose-psc mailing list
> geomoose-psc at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geomoose-psc
URL: <http://lists.osgeo.org/pipermail/geomoose-psc/attachments/20130213/aeda9b72/attachment.html>
More information about the geomoose-psc
