[geomoose-psc] git workflow notes on demo
James Klassen klassen.js at gmail.com
Fri Apr 10 19:04:56 PDT 2015
That's sort of (but not completely) setup for other versions of the demo
(similar to the docs).  Each branch has a lot of config before it auto
updates.
Probably would be good to have a 2.x.whatever demo too (synced with the
last official release instead of master).
On Apr 10, 2015 7:45 PM, "Eli Adam" <eadam at co.lincoln.or.us> wrote:
> At some point we could discuss an alternate demo branch(es).  This would
> be another branch that we run another demo off of.  This could be
> especially useful for having people test issues in review.  A workflow
> like: fix the issue in master, config alt demo to be relevant to that fix,
> put issue into review and link to alt demo, then reporter can test the
> issue without figuring out how to run trunk.
> Eli
> On Fri, Apr 10, 2015 at 5:09 PM, James Klassen <klassen.js at gmail.com>
> wrote:
>> It still could be documented better.   Like how to update a branch other
>> than master, etc.
>> On Apr 10, 2015 7:01 PM, "Eli Adam" <eadam at co.lincoln.or.us> wrote:
>>> On Fri, Apr 10, 2015 at 3:57 PM, James Klassen <klassen.js at gmail.com>
>>> wrote:
>>>> I should note if you have local changes in a submodule, they need to be
>>>> separately pushed before running this script.  Otherwise, the referenced
>>>> commits won't be at github.
>>>> On Apr 10, 2015 5:53 PM, "James Klassen" <klassen.js at gmail.com> wrote:
>>>>> https://github.com/geomoose/geomoose-utils/blob/master/update_to_master.sh
>>> Ah, great, even better place for it.  I should have looked there first.
>>> Thanks, Eli
>>>> On Apr 10, 2015 4:34 PM, "Eli Adam" <eadam at co.lincoln.or.us> wrote:
>>>>>> Hi Jim,
>>>>>> You diligently keep the sub-modules in geomoose/geomoose/ updated so
>>>>>> that the demo is reflective of the current commits.  Can you note the
>>>>>> commands that you use to push these two commits?
>>>>>> https://github.com/geomoose/geomoose/commit/5f2c3b65717462aa822827efca90681d9898a121
>>>>>> https://github.com/geomoose/geomoose/commit/5955f838d6e60bc632b1e1847699b089191aa07f
>>>>>> I appreciate you keeping things current.
>>>>>> Thanks, Eli
>>>>>> _______________________________________________
>>>>>> geomoose-psc mailing list
>>>>>> geomoose-psc at lists.osgeo.org
>>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geomoose-psc
URL: <http://lists.osgeo.org/pipermail/geomoose-psc/attachments/20150410/3e9a9a45/attachment.html>
More information about the geomoose-psc mailing list
