[geomoose-psc] PHP file system traversal vulnerability.
Jim Klassen klassen.js at gmail.com
Tue Apr 4 15:43:56 PDT 2017
I'd vote announce.  The announcement has the fix to existing users
attached (update download.php).
On 04/04/2017 05:05 PM, Dan Little wrote:
> I just heard back from Jeff, he's going to have a new MS4W package in
> the morning.  Barring objection, I'd like to save the larger public
> announcement until then as we know all the packages are then up to date.
> On Tue, Apr 4, 2017 at 3:51 PM, James Klassen <klassen.js at gmail.com
> <mailto:klassen.js at gmail.com>> wrote:
>     Good points.
>     Also, I have made 2.7.2, 2.8.2, and 2.9.3 releases with the fix.
>     On Apr 4, 2017 15:42, "TC Haddad" <tchaddad at gmail.com
>     <mailto:tchaddad at gmail.com>> wrote:
>         Hey Dan,
>         FWIW, the text of your proposed email looks good. I think you
>         could replace the three references to 'bug' with 'security
>         issue' and that is more likely to get people's attention /
>         quick action.
>         I feel like when there are security releases in other
>         projects, the information on the users list is kept to a
>         minimum - just the facts of the release, relevant download
>         links, and not a lot of info on the nature of the exploit.
>         So given that you could even just end your first paragraph
>         after "earlier versions of the 2.X series may also be
>         affected."... if you think that's enough detail.
>         Tanya
>         On Tue, Apr 4, 2017 at 12:48 PM, James Klassen
>         <klassen.js at gmail.com <mailto:klassen.js at gmail.com>> wrote:
>             Right.
>             I will also hide the bad versions on the downloads (and
>             redirect them to current).
>             On Apr 4, 2017 14:46, "Dan Little"
>             <theduckylittle at gmail.com
>             <mailto:theduckylittle at gmail.com>> wrote:
>                 I suspect it will be but don't want to be offering
>                 fresh downloads with the bug.
>                 On Tue, Apr 4, 2017 at 2:44 PM, James Klassen
>                 wrote:
>                     Yep, this deserves immediate action.   will build
>                     new releases of the 2.7+ branches as soon as I can.
>                     Although people dropping in the updated
>                     download.php from master is probably the qucker
>                     and easier patch.
>                     On Apr 4, 2017 14:23, "Dan Little"
>                         Hey Folks,
>                         Looking for some advice on how to handle a
>                         GeoMoose Security bug.  A user reported
>                         earlier today that the download.php script
>                         allowed for file system traversal by
>                         normalizing paths.  E.g:
>                             http://demo.geomoose.org/master/php/download.php?id=foo/.&ext=/../../../../../../../etc/passwd
>                             <http://demo.geomoose.org/master/php/download.php?id=foo/.&ext=/../../../../../../../etc/passwd>
>                         The call above was actually returning the
>                         password file.   I have a new version of
>                         download.php that I've put into master, r2.7,
>                         r2.8, r2.9. It can be seen here:
>                         - https://github.com/geomoose/geomoose-services/blob/master/php/download.php
>                         <https://github.com/geomoose/geomoose-services/blob/master/php/download.php>
>                         The user's list should be notified immediately
>                         but I suspect it would be good for us to have
>                         instructions written and new packages available.
>                         Here's my draft for the user's list:
>                         (start)
>                         ALL USERS!!!
>                         A bug in GeoMoose was identified that affects
>                         many  versions of GeoMoose.  The earliest
>                         version of the bug we have been able to
>                         identify is GeoMoose 2.7 but earlier versions
>                         of the 2.X series may also be affected.  This
>                         bug allows a well crafted URL to access the
>                         contents of nearly any file on the file system.
>                         The fix for this is easy and works the same
>                         for all versions of GeoMoose.  Find your copy
>                         of "download.php" and replace it with this one:
>                         - https://github.com/geomoose/geomoose-services/raw/master/php/download.php
>                         <https://github.com/geomoose/geomoose-services/raw/master/php/download.php>
>                         This version has been tested and does not
>                         exhibit the bug.
>                         *Please* update your GeoMoose installations as
>                         soon as possible.
>                         Thank You,
>                         The GeoMoose Team
>                         (end)
>                         Any feed back is welcome, please let me know!
>                         If I don't hear from anyone by tomorrow
>                         morning I'm going to drop the above message.
>                         _______________________________________________
>                         geomoose-psc mailing list
>                         geomoose-psc at lists.osgeo.org
>                         <mailto:geomoose-psc at lists.osgeo.org>
>                         https://lists.osgeo.org/mailman/listinfo/geomoose-psc
>                         <https://lists.osgeo.org/mailman/listinfo/geomoose-psc>
URL: <http://lists.osgeo.org/pipermail/geomoose-psc/attachments/20170404/2febe60c/attachment-0001.html>
More information about the geomoose-psc mailing list
