[geomoose-psc] https for geomoose.org
James Klassen
klassen.js at gmail.com
Fri May 26 17:39:25 PDT 2017
Yep.
On May 26, 2017 18:29, "Eli Adam" <eadam at co.lincoln.or.us> wrote:
> On Thu, May 25, 2017 at 7:23 PM, Jim Klassen <klassen.js at gmail.com> wrote:
> > Looks like the "OpenStreetMap - Black and White" layer is the only one
> > that isn't available over https. I have updated the rest of the
> > externally referenced layers in master as well as the google maps API
> > and copied the foss4g2017 logo internally.
> Looks like this was for 2.# demo, not 3.0.
> Eli
> > On 05/25/2017 06:51 PM, Eli Adam wrote:
> >> On Thu, May 25, 2017 at 4:53 AM, Dan Little <theduckylittle at gmail.com>
> wrote:
> >>> Sorry this is only a partial answer...
> >>> We can move almost all of that stuff to schemaless urls. Simply remove
> >>> "http:" from the URL and they'll automatically switch between http and
> >>> https.
> >>> On Wed, May 24, 2017 at 10:24 PM, Jim Klassen <klassen.js at gmail.com>
> wrote:
> >>>> I have enabled https on the *.geomoose.org sites. Besides generally
> >>>> being considered a good idea lately, and Let's Encrypt making it
> trivial
> >> Yes, good to use https, also if we use https, that is useful testing
> >> for people who want to run with https.
> >> Let's Encrypt is good but we need to have our automated renewal
> >> working well. Some sites seem to never figure that out and are always
> >> down because of it.
> >>>> and free to do so, the motivation is that some features in GeoMoose
> 3.0,
> >>>> most notably the "Find Me", are blocked by Chrome if they don't
> >>>> originate from an a site served by https.
> >>>> This does cause some warnings and blocking now from pulling things in
> >>>> from non-https external sites.
> >>>> The FOSS4G image hosted at mapserver.org has no https equivalent
> that I
> >>>> have found. We could self host as an easy work around.
> >> Seems that this should be hosted on http://2017.foss4g.org/ but that
> >> isn't https either.
> >>>> The Google maps API in 2.x is pulled in using
> >>>> http://maps.googleapis.com and not https://maps.googleapis.com (or
> >>>> //maps.googleapis.com).
> >>>> OpenStreetMap is pulled in from XYZ using http (defined in the
> mapbook)
> >>>> ArcGIS 9.3 Rest Example is pulled in using http.
> >>>> Weather Radar is pulled in using http.
> >>>> These will require a patches to all the active 2.x series branches so
> >>>> they are picked up in the demo.
> >>>> There is probably more, but this is what I found in a quick test. I
> >>>> haven't checked if the remote sites are available over https or not.
> If
> >>>> they are not, are the mixed-content warnings acceptable?
> >> If we are demonstrating an https instance, that doesn't really do it.
> >>>> Other thoughts?
> >> https is sometimes slower which could make the demo look slow but it
> >> still seems plenty fast to me testing (although with many images http
> >> that isn't really testing anything).
> >> Thanks for doing this Jim.
> >> Eli
> >>>> _______________________________________________
> >>>> geomoose-psc mailing list
> >>>> geomoose-psc at lists.osgeo.org
> >>>> https://lists.osgeo.org/mailman/listinfo/geomoose-psc
URL: <http://lists.osgeo.org/pipermail/geomoose-psc/attachments/20170526/a5316478/attachment.html>
More information about the geomoose-psc
