[geomoose-psc] GeoMoose Doc building
Jim Klassen
klassen.js at gmail.com
Mon Mar 22 08:50:41 PDT 2021
This is what I use to build the docs on the server:
$SPHINX_VENV/bin/sphinx-build -En $SOURCE_DIR/gm3/docs $HTML_DOCS_DIR/3.x
There are many ways someone could install sphinx that would work:
https://www.sphinx-doc.org/en/master/usage/installation.html
On the server, I've got it sphinx installed in a virtualenv with pip (pip install sphinx). The version of sphinx in the distributions (apt-get/yum/dnf/...) tend to be too far out of date so installing from pip/conda/etc. is preferred. I know that Sphinx 1.6.7 which is packaged with Ubuntu 18.04 is too old.
The server is currently running Sphinx 3.4.2, but newer should work. Older will probably work to a point. I don't remember how far back that point is at the moment.
On 3/22/21 9:55 AM, Brent Fraser wrote:
> Hi All,
> So I thought I would start integrating my Vector Editing doc into the code base at geomoose/gm3/docs. But there doesn't seem to be any info/scripts in the repo for building our doc. Should there be?
> Thanks!
> Brent
> geomoose-psc mailing list
> geomoose-psc at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geomoose-psc
URL: <http://lists.osgeo.org/pipermail/geomoose-psc/attachments/20210322/9ad08e7c/attachment.html>
More information about the geomoose-psc
