[geomoose-psc] GeoMoose Doc building
Jim Klassen
klassen.js at gmail.com
Mon Mar 22 11:03:47 PDT 2021
Then the basic `sphinx-build -En src_dir dst_dir` command is all they need. Even the `-En` options aren't strictly necessary. They just increase the warning level and avoid some potential caching issues.
On 3/22/21 12:14 PM, Brent Fraser wrote:
> I was just thinking of including a little bit of doc for the new/casual user on how it contribute to the doc:
> Contributing to GeoMoose Documentation
> Our doc uses reStructureText format....
> Clone the repo by ....
> To create HTML from .rst install Sphinx...., run make or our make.bat...
> Submit a pull request contain your doc contribution....
> or something like that.
> Brent
> *From*: Jim Klassen <klassen.js at gmail.com>
> *Sent*: 3/22/21 9:50 AM
> *To*: geomoose-psc at lists.osgeo.org
> *Subject*: Re: [geomoose-psc] GeoMoose Doc building
> This is what I use to build the docs on the server:
> $SPHINX_VENV/bin/sphinx-build -En $SOURCE_DIR/gm3/docs $HTML_DOCS_DIR/3.x
> There are many ways someone could install sphinx that would work:
> https://www.sphinx-doc.org/en/master/usage/installation.html
> On the server, I've got it sphinx installed in a virtualenv with pip (pip install sphinx). The version of sphinx in the distributions (apt-get/yum/dnf/...) tend to be too far out of date so installing from pip/conda/etc. is preferred. I know that Sphinx 1.6.7 which is packaged with Ubuntu 18.04 is too old.
> The server is currently running Sphinx 3.4.2, but newer should work. Older will probably work to a point. I don't remember how far back that point is at the moment.
> On 3/22/21 9:55 AM, Brent Fraser wrote:
>> Hi All,
>> So I thought I would start integrating my Vector Editing doc into the code base at geomoose/gm3/docs. But there doesn't seem to be any info/scripts in the repo for building our doc. Should there be?
>> Thanks!
>> Brent
>> geomoose-psc mailing list
>> geomoose-psc at lists.osgeo.org <mailto:geomoose-psc at lists.osgeo.org>
>> https://lists.osgeo.org/mailman/listinfo/geomoose-psc
URL: <http://lists.osgeo.org/pipermail/geomoose-psc/attachments/20210322/7e4f9c92/attachment-0001.html>
More information about the geomoose-psc
