[geomoose-psc] GeoMoose GeoParquet Support
Eli Adam
eadam at co.lincoln.or.us
Mon Oct 5 07:07:55 PDT 2026
Hi all,
This has been paid (and decremented our OSGeo budget leaving a remainder of $200).
This email completes housekeeping on this topic.
Best regards, Eli
Sent: Monday, August 31, 2026 8:09 PM
To: GeoMOOSE PSC <geomoose-psc at lists.osgeo.org>; Dan Little <theduckylittle at gmail.com>
Subject: Re: [geomoose-psc] GeoMoose GeoParquet Support
Hi all,
I submitted this to the OSGeo Treasurer for payment.
Best regards, Eli
Sent: Tuesday, August 18, 2026 3:00 PM
To: GeoMOOSE PSC <geomoose-psc at lists.osgeo.org>; Dan Little <theduckylittle at gmail.com>; Eli Adam <eadam at co.lincoln.or.us>
Hi Dan and all,
Looping back on this, it looks like these items have been completed. Please submit an invoice for payment not exceeding $2,000. I've also put this on the PSC agenda to review processing invoices.
Best regards, Eli
From: geomoose-psc <geomoose-psc-bounces at lists.osgeo.org> on behalf of Eli Adam via geomoose-psc <geomoose-psc at lists.osgeo.org>
Sent: Tuesday, April 14, 2026 1:33 PM
Hi Dan,
This is exciting development! As people test it out, we'll learn more about how it is working.
>From a bookkeeping perspective, look back to the initial scope (https://lists.osgeo.org/pipermail/geomoose-psc/attachments/20260119/a519ae6e/attachment.md) and once complete, submit an invoice for processing by the PSC.
I haven't tested GeoParquet yet but a quick look (that may have missed things) suggests that "1. Host a version of the demonstration parcel dataset in GeoParquet format on GitHub" may be met with an equivalent public google bucket. I don't see that 2. has been completed, "2. Publish the instructions for how the conversion from the parcel shapefile was performed. This should appear as a How To in the documentation repository." Again, I only took a glance and may have missed things.
Thanks for the exciting improvement!
Best regards, Eli
From: geomoose-psc <geomoose-psc-bounces at lists.osgeo.org> on behalf of Dan Little via geomoose-psc <geomoose-psc at lists.osgeo.org>
Sent: Monday, April 13, 2026 10:18 AM
Subject: [geomoose-psc] GeoMoose GeoParquet Support
Hi Folks!
I wanted to get an update on the GeoParquet in GeoMoose support out to the PSC. The original proposal had us concluding this at the end of March. 95% of the code was done then but I had an itch I wanted to scratch -- adding WebWorker support for GeoParquet layers. The WebWorker support allows Parquet files to be loaded without over-burdening the main rendering thread for the application.
The current code is available here:
- https://github.com/geomoose/gm3/pull/938
I used DuckDB to convert the GeoJSON version of the Parcels to GeoParquet, put the output in a public google bucket, and then continued to Dev. I also keep a copy locally for when working from planes. :-)
This should all work seamlessly with the current demo.
At this point, I would consider this the conclusion of the scope of work (and a little more got done as well) but would love bug reports and feedback!
URL: <http://lists.osgeo.org/pipermail/geomoose-psc/attachments/20261005/a25e1825/attachment-0001.htm>
More information about the geomoose-psc
