[geomoose-psc] Modernizing GeoMoose UX
Bob Basques
bbasques at sharedgeo.org
Fri Oct 9 15:52:22 PDT 2026
All,
I think I'm generally in favor of anything that follows the
system preference, I use dark themes whenever possible as well, so . . .
and because you asked . . .
An option. for inverting the map display would be great, especially for
night/dim light viewing, or maybe call it night view? like so:
https://www.dropbox.com/scl/fi/3plhippx4hhhnhv701s5k/main.png?rlkey=icjqk9v6ijwxqodkz6yn74oc6&st=ui8yn3ps&dl=0
I know there are option in chrome and Opera I think to this, even by
default, but I like personally to have a control/button to hit.
bobb
On Thu, Oct 8, 2026 at 9:45 AM Dan Little via geomoose-psc <
geomoose-psc at lists.osgeo.org> wrote:
> Hey folks,
> I did some work to push a human interface guideline compliant version of
> GeoMoose. This, more or less, heavily tweaks the default theme and cleans
> up how the LESS is structured to be easier to stylize and handle light/dark
> modes.
> My initial version was based on the GNOME & COSMIC desktops. It's what I
> use, personally, but also I have a preference for it these days. That work
> can be seen here:
> - https://github.com/geomoose/gm3/pull/1044
> Jim has some different thoughts (and defaults), so I did a fork of the
> GNOME-inspired version and used the KDE HIG for a run. Those results are
> here:
> - https://github.com/geomoose/gm3/pull/1045
> A few questions for the larger group:
> 1. Do folks like one or either of these?
> 2. Is adopting a new default style worth the potential disruption?
> Please don't try to nit-pick some of the smaller details. This is a
> quick-pass starting point that would take some real user feedback and
> workflow clean up to be totally plausible. We can make some decisions
> ourselves as well to deviate from some of the HIGs if we decided to adopt
> one.
> I have a dream where our standard theme is a bit more modern and where we
> tell users "Set this accent color variable(s)" and we do smart things with
> making the theme fit the user's branding better.
> Cheers!
> geomoose-psc mailing list
> https://lists.osgeo.org/mailman/listinfo/geomoose-psc
Bob Basques
612.598.9210
You can book an appointment here . . .
<https://calendar.app.google/fZXkerwEZEyudL2a8>
URL: <http://lists.osgeo.org/pipermail/geomoose-psc/attachments/20261009/790a5171/attachment.htm>
More information about the geomoose-psc
