[Geomoose-users] How do I load imagery from a wms server
Jim Klassen Jim.Klassen at ci.stpaul.mn.us
Wed Dec 5 13:13:29 EST 2007
Can you send your mapfile to the list?
I am curious what is in the older mapfiles that is causing GeoMOOSE
problems. In particular, I think the request moose uses to get the map
image (as opposed to say an identify request) from mapserver is pretty
standard and so should just work... But clearly since it doesn't I'm
missing something.
-----Original Message-----
To: "Bob Basques" <Bob.Basques at ci.stpaul.mn.us>
Cc: "GeoMoose Users" <geomoose-users at lists.sourceforge.net>
Sent: 12/5/07 11:50 AM
Subject: Re: [Geomoose-users] How do I load imagery from a wms server
I have an old  site using mapserver and dbox that loads  wms data fine
but the same code does not appear to work in  Geomoose.
I guess I need to keep plugging
Bob Basques wrote:
> Gary,
> There is a layer in the demo dataset being requested via a WMS
> service.  This can be used as a template for the configuration.  If
> the service doesn't support your projection however, you will need to
> have the results reprojected in some manner, the suggested method
> would be to set up MapServer as a Client to the original WMS and then
> have MapServer reproject the WMS results to your desired projection.
> You can get more ino on this from the MapServer WebSite.
> bobb
> >>> Gary Watry <watry at steam.coaps.fsu.edu> wrote:
> Any thoughts, My display is in
> Lambert Conformal Equal Area (U.S. National Atlas Equal Area) (SRID
2163)
> SF.Net email is sponsored by: The Future of Linux Business White Paper
> from Novell.  From the desktop to the data center, Linux is going
> mainstream.  Let it simplify your IT future.
> http://altfarm.mediaplex.com/ad/ck/8857-50307-18918-4
> Geomoose-users mailing list
> Geomoose-users at lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users mailing list
