[Geomoose-users] Setting projection in GeoMoose
Johnson, Jeremy JJohnson at ci.blaine.mn.us
Fri Dec 7 16:07:37 EST 2007
If you read that a little closer, this has nothing to do with displaying
data from projections other than UTM-15.  I thought the same thing too
when I found the page.
Projection support in GeoMOOSE is used to convert the coordinate system
of the map into lat-lon and back. This is only used to display the
lat-lon coordinates in the status bar and for passing lat-lon
information into a service. This does NOT re-project any images or data
that are retrieved from Mapserver or WMS services.
From: geomoose-users-bounces at lists.sourceforge.net
[mailto:geomoose-users-bounces at lists.sourceforge.net] On Behalf Of Jim
Dahl
Sent: Friday, December 07, 2007 3:06 PM
To: geomoose-users at lists.sourceforge.net
Subject: [Geomoose-users] Setting projection in GeoMoose
After reading the how to :
http://www.geomoose.org:88/moose/documentation/how-tos/how-to-add-your-o
wn-projection
<http://www.geomoose.org:88/moose/documentation/how-tos/how-to-add-your-
own-projection>  I am still not sure what I have to do to set up my
interface to use County Projected data.  I see the MN county projections
are in the lib js file and the projection/MNcounty js file.  So that
must leave the configuration js file where there is just one reference
to UTM-15.  Is this something that is quick to do?
Jim Dahl, GISP
GIS Coordinator
Douglas County Public Works
509 3rd Ave W
PO Box 398
Alexandria MN 56308
V 320-762-2933
   320-763-6001
F 320-763-7955
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20071207/b09f18b8/attachment.html
More information about the Geomoose-users mailing list
