[Geomoose-users] FW: Popup Legend How to
Fischer, Brian
bfischer at houstonengineeringinc.com
Thu Nov 1 16:19:02 EDT 2007
Jim,
You are correct the state demo application is not configured to show the
data popup functionality. This is something we are planning on
addressing in the 1.2 code, but for now to get the popups you would need
to edit the configuration.js file to show a tools tab. I'm just going
of of memory, but here are the things you would need to change,
hopefully I did not miss anything.
1) "var MAP_POPUPS_ENABLED = true;" - make sure this variable is true.
2) add a tools tab by setting this variable to true - "var
TOOLS_SHOW_TAB = true;"
I think that is all you have to do to get the radio buttons to show up
under a tools tab.
Brian Fischer
Houston Engineering, Inc.
Maple Grove, MN
(763) 493-4522
From: geomoose-users-bounces at lists.sourceforge.net
[mailto:geomoose-users-bounces at lists.sourceforge.net] On Behalf Of Jim
Dahl
Sent: Thursday, November 01, 2007 11:16 AM
To: geomoose-users at lists.sourceforge.net
Subject: [Geomoose-users] Popup Legend How to
I really like the documentation but can't seem to get the popup working
using the sample for the State Parks. Looks like the configuration.js
needs editing to enable it. However, I don't see the documentation for
this, other than the radio button needs to be present and the background
should be blue to show popups available.
Thanks,
Jim Dahl, GISP
GIS Coordinator
Douglas County Public Works
509 3rd Ave W
PO Box 398
Alexandria MN 56308
V 320-762-2933
320-763-6001
F 320-763-7955
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20071101/d66dcf15/attachment.html
More information about the Geomoose-users
