[Geomoose-users] [Geomoose-developers] Search Menu / Tab
Dan Little
danlittle at yahoo.com
Wed Nov 7 09:43:59 EST 2007
A HA! Now I see it (do not know why it took me so long before).
This is a general GeoMOOSE bug. Right now only one service can be "called" at a time. When you put them all onto the same tab it tries to use all of the inputs in that tab and send them all to the same service. Functionally it gets very confused. Brian and I have have been back and forth about whether to make this fix for 1.2 or 1.6
----- Original Message ----
From: Jay Kapalczynski <jkapalczynski at ci.maple-grove.mn.us>
To: Bob Basques <Bob.Basques at ci.stpaul.mn.us>; geomoose-developers at lists.sourceforge.net; geomoose-users at lists.sourceforge.net
Sent: Wednesday, November 7, 2007 8:40:48 AM
Subject: Re: [Geomoose-users] [Geomoose-developers] Search Menu / Tab
_filtered {font-family:"Cambria Math";panose-1:2 4 5 3 5 4 6 3 2 4;}
_filtered {font-family:Calibri;panose-1:2 15 5 2 2 2 4 3 2 4;}
_filtered {font-family:Tahoma;panose-1:2 11 6 4 3 5 4 4 2 4;}
_filtered {font-family:Consolas;panose-1:2 11 6 9 2 2 4 3 2 4;}
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{margin:0in;margin-bottom:.0001pt;font-size:11.0pt;font-family:"Calibri", "sans-serif";}
a:link, span.MsoHyperlink
{color:blue;text-decoration:underline;}
a:visited, span.MsoHyperlinkFollowed
{color:purple;text-decoration:underline;}
p.MsoPlainText, li.MsoPlainText, div.MsoPlainText
{margin:0in;margin-bottom:.0001pt;font-size:10.5pt;font-family:Consolas;}
p.MsoAcetate, li.MsoAcetate, div.MsoAcetate
{margin:0in;margin-bottom:.0001pt;font-size:8.0pt;font-family:"Tahoma", "sans-serif";}
span.PlainTextChar
{font-family:Consolas;}
span.BalloonTextChar
{font-family:"Tahoma", "sans-serif";}
.MsoChpDefault
_filtered {margin:1.0in 1.0in 1.0in 1.0in;}
div.Section1
This is what I am getting when I try and search the first….It
appears to be a query error
but when I search the second everything works fine…
NOTE: If I move the order around it is still the first
that does not work and the second that does work.
So it doesn’t seem to be the query or the data….they
each run perfect themselves…they don’t break down untill I place
two or more on the tab at the same time…
I am lost here…..anyone?
-----Original Message-----
From: Bob Basques [mailto:Bob.Basques at ci.stpaul.mn.us]
Sent: Tuesday, November 06, 2007 4:25 PM
To: geomoose-developers at lists.sourceforge.net; geomoose-users at lists.sourceforge.net;
Jay Kapalczynski
Subject: Re: [Geomoose-developers] Search Menu / Tab
Jay,
Not positive about this, but I did notice the
capitalization on the two different "value" parameters are not the
same, the second one is all capitalized, there may be a need to keep them one
way or the other, my gut feeling is that they need to be capitalized, as the
value is used to match against a data column/type of some sort.
Real quickly, you could swap their display order around
and see if the same one still works or not, then you'll know if it's the data
of the query that's at fault.
bobb
>>> "Jay Kapalczynski"
<jkapalczynski at ci.maple-grove.mn.us> wrote:
I have been working on getting a tab running to do my
searches. I have somewhat succeded in that I created a new tab and I can copy
some of the code that allows the user to enter a Park Name and search for it
and zoom to it...
Although I want to take this a bit further and have
multiple searches on the same tab
Right now I modified the menu to allow for searches on
Park, Parcel PID, and Street Name.
Each one is working properly from the Menu
My problem is when I try and bring this code to the
Tab..as long as I stay with just one of the searches I am ok.it breaks down
when I try and bring more than one..then only the last one works...
I created a new entry in the Menue Title (statemenu.xml)
<menu title="Search">
<item
title="Search for Parks"
href="javascript:ServManager.startService('Search for Parks')"/>
<item
title="Search for PID"
href="javascript:ServManager.startService('Search for PID')"/>
<item
title="Search for Street"
href="javascript:ServManager.startService('Search for Street')"/>
<item
title="Search for Stuff"
href="javascript:ServManager.startService('Search for Stuff')"/>
</menu>
I created a new entry in the service title
(statedemo.xml)
<service
title="Search for Stuff" selectable="false"
default="false" locked="true"
div="StuffSearch">
<url>/cgi-bin/mapserv.exe</url>
<input
type="hidden" name="map"
value="/ms4w/apps/GeoMOOSE/maps_statedemo/itemquery_Stuff.map"/>
<input
type="hidden" name="mode" value="nquery"/>
<input
type="user" name="id" title="Zoom to Stuff:"/>
</service>
I create a new entry for the search (statedemo.html)
<div id="StuffSearch">
<font
color="black"><b>Search for
Park:</b></font><br/>
<input
name="id"/><input type="submit"
value="Search_Park"/>
<input type="hidden"
name="map" value="/ms4w/apps/GeoMOOSE/maps_statedemo/itemquery.map"/>
<br><i>Enter Park
Name.<i/>
<font
PID:</b></font><br/>
<input
value="SEARCH_PID"/>
name="map"
<br><i>Enter PID
number.<i/> </div>
When written like above you can see both of them but only
the second one works..the first errors out.
ANY THOUGHTS WH Y BOTH WILL NOT WORK?
OR ANY THOUGHTS HOW I CAN GET THIS TO WORK?
THanks
Jay
-----Inline Attachment Follows-----
This SF.net email is sponsored by: Splunk Inc.
Still grepping through log files to find problems? Stop.
Now Search log events and configuration files using AJAX and a browser.
Download your FREE copy of Splunk now >> http://get.splunk.com/
__________________________________________________
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
Skipped content of type multipart/related
More information about the Geomoose-users
