[Geomoose-users] ***PROBABLY FRAUD*** RE: (no subject)
Scott Oatley
swoatley at gmail.com
Mon Nov 12 19:34:54 EST 2007
Greetings!
I downloaded your files, and put them in my GeoMOOSE setup. I had to do four
things to get the aktogrammi layer to display.
1. The aktogrammi.map file in the RAR file was different than the separate
attachment. The one in the RAR file was looking for a roads.shp file.
LAYER
NAME "aktogrammi"
STATUS ON
DATA *"./roads.shp"*
TYPE LINE
CLASS
NAME "main road"
EXPRESSION ('[Id]' eq '1')
STYLE
COLOR 0 0 0
END
END
END
2, 3 and 4. After swapping the map files, I made the following two changes
to the file: changed status from ON to DEFAULT, changed TYPE from LINE to
POLYGON, and commented out the EXPRESSION statement.
LAYER
NAME "aktogrammi"
DATA "./aktogrammi.shp"
STATUS *DEFAULT*
TYPE *POLYGON*
CLASS
NAME "main road"
*# EXPRESSION ('[Id]' eq '1')*
STYLE
COLOR 10 40 100
END
END
END
I used your statedemo2.xml file with the above changes, and the map
displayed correctly in my GeoMOOSE session.
NOTES:
I don't know enough about the LAYER-STATUS to answer why that change was
needed. I just set it to default because that's what setting I've used in
all my map files.
I believe the EXPRESSION statement will require a CLASSITEM statement to
support it. In the example below, "FEATURE" is the name of an attribute in
the shape file, and the expressions refer to specific values in that field.
LAYER
NAME 'bvwatercc'
DATA './water_cc.shp'
STATUS DEFAULT
TYPE POLYGON
CLASSITEM "FEATURE"
CLASS
NAME 'BV Lakes cc'
EXPRESSION '104'
STYLE
COLOR 200 200 255
OUTLINECOLOR 0 0 0
WIDTH 1
END
END
CLASS
NAME 'BV Marshes cc'
EXPRESSION '105'
STYLE
COLOR 250 0 0
OUTLINECOLOR 0 0 0
WIDTH 1
END
END
END #layer
Hope this helps you get mapping!!
Scott
On Nov 12, 2007 12:50 PM, Athanasis Nikolaos <athanasis at geo.aegean.gr>
wrote:
> Hello,
> Thank you for your answers,
> If you click on page:
> http://195.251.137.181/cgi-bin/mapserv.exe?map=/ms4w/apps/GeoMOOSE/maps_statedemo2/county/aktogrammi.map&mapext=638840.8910586574%204310740.53966996%20745390.3095982376%204366667.28424747&mapsize=1366%20717&mode=map
> you will see that there are no errors anymore in the map file . Actually,
> my map file was correct, however I had to save it from my Notepad as
> Unicode text document in order to work properly.
> However, only a white page comes in my web browser when I click on the
> URL of my application
> http://195.251.137.181/geomoose/statedemo2.html
> I believe that something is not correct in my mapbook. All I did there is
> to add :
> <map title="aktogrammi" default="true">
> <file>/ms4w/apps/GeoMOOSE/maps_statedemo2/aktogrammi/aktogrammi.map</file>
> </map>
> and i also removed all pre-set layers (specified my <map> elements) .
> However, some <map> elements (e.g. scalebar) are not removed. Is this
> correct?
> finally, i corrected
> <view title="Full State View" default="true" invisible="true">
> 189783.560000,4816309.330000,761653.524114,5472346.500000</view>
> and put the approrpiate extent of my map.
> In the attachment files, you will find the map file, the
> corresponding shape file (in a rar file) and the .xml mapbook file of my
> GeoMoose application.
> I would appreciate if you could give me any ideas what is still wrong....
> Thank you, very much,
> Athanasis Nikolaos
> Adjunct Faculty and Ph.D. Candidate,
> Department of Geography and Department of Cultural Technology and
> Communication
> University of the Aegean
> University Hill
> 81100 Mytilene, GREECE
> TEL +30-22510-36436
> *Από:* Fischer, Brian [mailto:bfischer at houstonengineeringinc.com]
> *Αποστολή:* Σαβ 10/11/2007 7:30 μμ
> *Προς:* Athanasis Nikolaos; Jim Klassen;
> Geomoose-users at lists.sourceforge.net
> *Θέμα:* ***PROBABLY FRAUD*** RE: [Geomoose-users] (no subject)
> It looks like the mapfile has some errors in it. Look at this URL and
> you will get the error message.
> If you can send your .xml and .map, we can help you out a little more.
> -Brian
> *From:* geomoose-users-bounces at lists.sourceforge.net [mailto:
> geomoose-users-bounces at lists.sourceforge.net] *On Behalf Of *Athanasis
> Nikolaos
> *Sent:* Tuesday, November 06, 2007 12:43 PM
> *To:* Jim Klassen; Geomoose-users at lists.sourceforge.net
> *Subject:* Re: [Geomoose-users] (no subject)
> Thank you very much for all your responses, however it is impossible to
> make Geomoose work with my data.
> when I follow the how-to : "Basic How to Add Your Own Data Layers"
> (from the URL:
> http://www.geomoose.org/moose/documentation/how-tos/basic-how-to-add-your-own-data-layers)
> then everything seems ok and I can successfully add a new shp file (from the
> MN DNR data deli).
> Then I try to remove all map layers from the demo and add my own map
> elements for my own data.
> Thus:
> I created a new folder called aktogrammi under maps_statedemo folder where
> I put the data about a shapefile called aktogrammi (.shp, .prj, .sbn, .sbx,
> .dbf, .shx files)
> Then, I added the following
> <file>/ms4w/apps/GeoMOOSE/maps_statedemo/aktogrammi/aktogrammi.map</file>
> </map>
> into the statedemo.xml file
> I removed all <map> elements in the statedemo.xml files that corresponded
> to the existing map layers
> ( from '<map title="County Map" ' to 'map title="USGS 7.5' Quads"
> the aktogrammi.map file is the following:
> MAP
> NAME 'test_please_run!'
> SIZE 800 650
> PROJECTION
> 'init=epsg:2100'
> END
> STATUS ON
> EXTENT 654482.650706199 4310740.53966996 729748.549950696 4366667.28424747
> UNITS METERS
> FONTSET '../fonts/fontset.list'
> SYMBOLSET '../symbols/symbol.sym'
> TRANSPARENT TRUE
> IMAGETYPE PNG
> QUERYMAP
> STATUS ON
> STYLE SELECTED
> END
> WEB
> INCLUDE "/ms4w/apps/GeoMOOSE/maps_statedemo/web_config.map"
> END
> LEGEND
> STATUS ON
> END
> LAYER
> NAME 'aktogrammi'
> DATA './aktogrammi.shp'
> STATUS on
> TYPE Polygon
> CLASSITEM 'OBJECTID'
> CLASS
> NAME 'aktogrammi'
> STYLE
> COLOR 255 255 255
> OUTLINECOLOR 115 223 255
> END #STYLE
> END #CLASS
> END #LAYER
> END ## end Map
> I put the aktogrammi.map file in the aktogrammi folder.
> However, it does not work and unfortunatelly the log file of apache does
> not help at all.
> You can see the picture of my problematic application in the URL
> What could be the reason for this?
> I really thank you in advance!
> Athanasis Nikolaos
> Communication
> University Hill
> TEL +30-22510-36436
> *Από:* Jim Klassen [mailto:Jim.Klassen at ci.stpaul.mn.us]
> *Αποστολή:* Τρι 6/11/2007 5:19 μμ
> *Προς:* Athanasis Nikolaos; Geomoose-users at lists.sourceforge.net
> *Θέμα:* Re: [Geomoose-users] (no subject)
> It is UTM-15N.
> The projection support in GeoMoose has been developed on an as needed
> basis. Currently it is only used for two things. The first is displaying the
> lat-long in status bar at the bottom of the page. The second is if you
> invoke any services which require a lat-long input.
> If you want to add your own projection you can start here:
> http://www.geomoose.org/moose/documentation/how-tos/how-to-add-your-own-projection/ Basically,
> it involves writing a javascript function that takes in your coordinate
> pairs and returns lat-long.
> The imagery, identify and select tools are all controlled by Mapserver
> which has fairly good projection support through the Proj.4 library.
> GeoMoose just passes through what Mapserver returns, so there shouldn't be
> any problems with the core functionality.
> >>> On 11/5/2007 at 4:52 PM, "Athanasis Nikolaos" <athanasis at geo.aegean.gr>
> wrote:
> Hello list!
> I am a totally new user of GeoMoose. I believe that it is the best
> MapServer client.
> My question is the following: In the stateconfiguration.xml file, I must
> change the "var MAP_COORDINATE_SYSTEM = 'UTM-15';" variable and specify a
> different projection system (my data are in the GGRS87 projection system).
> 1. What exactly is the projection system of UTM-15 (maybe UTM Zone
> 15N or maybe UTM Zone 15S?) ?
> 1. Do I have to change the MAP_COORDINATE_SYSTEM variable?What are
> its valid values?
> The log file does not specify anything about what is going wrong.
> I really thank you in advance,
> Athanasis Nikolaos
> Communication
> University Hill
> TEL +30-22510-36436
> This SF.net email is sponsored by: Splunk Inc.
> Still grepping through log files to find problems? Stop.
> Now Search log events and configuration files using AJAX and a browser.
> Download your FREE copy of Splunk now >> http://get.splunk.com/
> Geomoose-users mailing list
> https://lists.sourceforge.net/lists/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20071112/36209f8d/attachment.html
More information about the Geomoose-users
