[Geomoose-users] Park Search Help
Fischer, Brian
bfischer at houstonengineeringinc.com
Tue Nov 13 23:19:53 EST 2007
Ok, I know what is going on. My guess is when you first downloaded the
MS4W package it was MapServer 4.10 and the latest one you downloaded
included MapServer 5.0 which requires a slight modification a mapfile.
Which is why it worked the first time, but not now. I just downloaded
the latest GeoMOOSE .zip and notice it does not have this parameter in
the mapfiles needed for the state demo. You will have to add this
parameter to any layer you are querying (technically it is any layer
that is using the qstring parameter in the URL). I think for the demo
you would only need to add it to the parks layer in the itemquery.map
and select.map files.
METADATA
qstring_validation_pattern '.'
END
You can read more about the parameter at
http://trac.osgeo.org/mapserver/browser/branches/branch-5-0/mapserver/MI
GRATION_GUIDE.TXT
Hopefully that does the trick. If not let me know.
Brian Fischer
Houston Engineering, Inc.
Maple Grove, MN
(763) 493-4522
From: geomoose-users-bounces at lists.sourceforge.net
[mailto:geomoose-users-bounces at lists.sourceforge.net] On Behalf Of Adam
Feidt
Sent: Tuesday, November 13, 2007 3:38 PM
To: geomoose-users at lists.sourceforge.net
Subject: [Geomoose-users] Park Search Help
I currently have the Park Search reconfigured to run off my own parks
shapefile, but the zoom to function only partially works. When I click
the "Zoom Map to Park" the map zooms to the specified park, but does not
highlight. My browser times out saying the "Highlight Layer" could not
draw. Here is my Map Server Error Message: mapserv(): Web application
error. Metadata qstring_validation_pattern is not set. Any ideas on
what I have messed up?
Adam M. Feidt
GIS Coordinator
City of Eden Prairie
8080 Mitchell Rd
Eden Prairie, MN 55344
phone# 952-949-8443
fax# 952-949-8334
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20071113/f6d25298/attachment.html
More information about the Geomoose-users
