[Geomoose-users] Labels in Reference Map
Gary Watry
watry at steam.coaps.fsu.edu
Fri Oct 19 10:34:33 EDT 2007
Thanks, that is what I thought
Bob Basques wrote:
> Gary,
> The best way to do this is to set up a layer that is only visible in the
> reference map window. While this may seem a bit tedious to do, it
> affords you the most complete control over the interface.
> You simply copy the .MAP files that are visible in the Main Map view
> that also have labels, that you want in the reference map and set those
> layers up to NOT display the labels.
> There are some settings in MAP files that are based on scale that you
> might want to take a look at too, that might help with this, like
> MINDISTANCE, MAXDISTANCE, etc. These can be used to tell MapServer when
> to labels things as well.
> The shorter answer to this is that any display properties in the images
> themselves are controlled by MapServer and it's configuration (MAP)
> files.
> bobb
>>>> Gary Watry <watry at steam.coaps.fsu.edu> 10/19/07 9:20 AM >>>
> Is there a way to have labels show on the main map view but not on the
> "Reference Map"?
> This SF.net email is sponsored by: Splunk Inc.
> Still grepping through log files to find problems? Stop.
> Now Search log events and configuration files using AJAX and a browser.
> Download your FREE copy of Splunk now >> http://get.splunk.com/
> Geomoose-users mailing list
> Geomoose-users at lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users
