[Geomoose-users] automatically turn map off / on on event
Janosch.Skrobek at trier.de
Wed Apr 16 08:42:23 EDT 2008
Hi everyone,
is there a way to automatically turn a map off or on when some event is triggered?
1) I have a map for the noise-pollution at night and one for the daytime. I would only one of them to be allowed to be displayed, so when the user clicks one map the other one should be turned off. Mapserver has "REQUIRED" for this but that doesn't seem to work since in geomoose you use various mapfiles and the layer isn't in the same file. Or is there a way to turn layers within a mapfile on and off in geomoose? I went through the documentation of the mapbook xml file but it only describes how to implement maps, not how to implement single layers from a map.
2) When you use the Identify tool and click on the map information about a layer is displayed disregarding whether it is activated or not in the treeview. Can I change this?
Regarding the Umlauts, thanks for your answer Dan. Where would I have to integrate the makeXMLSafeString function, meaning which file will I have to work on?
Thank you,
Janosch
Von: Dan Little [mailto:danlittle at yahoo.com]
Gesendet: Montag, 14. April 2008 16:19
An: Skrobek, Janosch; geomoose-users at lists.sourceforge.net
Betreff: Re: [Geomoose-users] special characters
There may also be an option with some of the GeoMOOSE files to provide for additional functionality using the "makeXMLSafeString" function.
The following string substitutions should create the proper output.
I am terribly at typing umlauts, so please read "ae" to mean "a with the umlauts"
"ae" = &$228;
"oe" = &$246;
"ue" = &$252;
"Ae" = &$196;
"Oe" = &$214;
"Ue" = &$220;
English users will probably not care... LOL.
----- Original Message ----
From: "Janosch.Skrobek at trier.de" <Janosch.Skrobek at trier.de>
To: geomoose-users at lists.sourceforge.net
Sent: Monday, April 14, 2008 8:51:00 AM
Subject: [Geomoose-users] special characters
Hi erveyone,
is there a way to have special characters like ä, ö, ü, etc properly displayed in Geomoose?
I tried setting the charset to utf-8 but the results from the querys are still not formatted properly. The database I use contains a lot of "umlauts" (Is that the right English word?) which I need to display when using the identify-tool...
You can see a screenshot of my problem here:
http://img356.imageshack.us/img356/5838/umlautevb9.jpg
Anyone who can help me?
Thanks
Janosch
Hinweis:
Diese E-Mail kann vertrauliche und/oder rechtlich geschützte Informationen enthalten.
Wenn Sie nicht der richtige Adressat sind oder diese E-Mail irrtümlich erhalten haben,
informieren Sie bitte sofort den Absender und vernichten Sie diese E-Mail. Das unerlaubte
Kopieren sowie die unbefugte Weitergabe dieser E-Mail ist nicht gestattet. Der
rechtsverbindliche elektronische Schriftverkehr mit der Stadt Trier ist über diese
E-Mail-Adresse derzeit noch nicht möglich.
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20080416/fd61bf29/attachment.html
More information about the Geomoose-users
