[Geomoose-users] [Geomoose-developers] Raster & contours
Fischer, Brian
bfischer at houstonengineeringinc.com
Fri Apr 25 17:16:33 EDT 2008
Adam, the only way to get good performance out of large rasters like
that or even shapefiles for the matter is to tile them
(http://mapserver.gis.umn.edu/docs/howto/optimizeraster or
http://mapserver.gis.umn.edu/docs/howto/optimizevector) . Also only let
your users display the layer at a lower scale. To tile a layer you can
use some gdal/ogr utilities that come with MS4W. Take a look at this
page for more guidance. http://www.gdal.org/gdal_utilities.html and
http://www.gdal.org/ogr/ogr_utilities.html and
http://mapserver.gis.umn.edu/docs/reference/utilityreference/tile4ms.
Hope this helps,
Brian
From: geomoose-developers-bounces at lists.sourceforge.net
[mailto:geomoose-developers-bounces at lists.sourceforge.net] On Behalf Of
Adam Feidt
Sent: Friday, April 25, 2008 11:59 AM
To: geomoose-developers at lists.sourceforge.net;
geomoose-users at lists.sourceforge.net
Subject: [Geomoose-developers] Raster & contours
I've got a fairly large city-wide ArcInfo Grid that displays elevation
data loaded in a Moose project. I'm trying to balance redraw times
without losing significant detail, but I am having problems because the
raster seems to be redrawing at different speeds. Initially it will
redraw around 30-45 seconds. Once it has loaded the redraw gets much
better around 2 to 5 seconds. Eventually after a little while the
redraw goes back to 30-45 seconds. Is mapserver caching the image for a
certain amount of time and after a specified time calling for it to
redraw? Can I adjust the settings for this layer to never redraw or to
store the cache permanently?
Also, it appears when I zoom in and out or go to full extent enough
times the layers stall and won't redraw. Is this a bug or how can I fix
this problem?
Adam M. Feidt
GIS Coordinator
City of Eden Prairie
8080 Mitchell Rd
Eden Prairie, MN 55344
phone# 952-949-8443
fax# 952-949-8334
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20080425/0a840fef/attachment.html
More information about the Geomoose-users
