[Geomoose-users] Angle Auto Not working
Fischer, Brian bfischer at houstonengineeringinc.com
Wed Aug 6 16:31:29 EDT 2008
Yes, this is completely a Mapserver feature.  I think you have to also
have LABELCACHE ON in your layer definition for that feature to work.
You'll have to look at the MapServer documentation to be sure.
-Brian
-----Original Message-----
From: Jim Dahl [mailto:jim.dahl at mail.co.douglas.mn.us]
Sent: Wednesday, August 06, 2008 10:45 AM
To: Fischer, Brian; geomoose-users at lists.sourceforge.net
Subject: Angle Auto Not working
Thanks for the clarification on the TEXT ANGLE options.  That makes
sense, but I couldn't get the ANGLE AUTO to function as you stated.
Should it work with the latest versions of MapServer and GeoMoose?  My
parcel labels remain horizontal.  Here is my anno class:
    CLASS
      LABEL
        TYPE TRUETYPE
        FONT arial
#       ANGLE FIELDNAME
	ANGLE FOLLOW
#	ANGLEITEM FIELDNAME
        MINSIZE 6
        SIZE 7
        MAXSIZE 9
        POSITION CC
        ANTIALIAS TRUE
        COLOR 0 0 0
        OUTLINECOLOR 254 254 254
        BUFFER 2
        MINFEATURESIZE AUTO
        PARTIALS FALSE
      END
    END
From: Fischer, Brian [mailto:bfischer at houstonengineeringinc.com]
Sent: Wednesday, August 06, 2008 10:20 AM
To: Jim Dahl; geomoose-users at lists.sourceforge.net
Subject: RE: [Geomoose-users] Geomoose-users Digest, Vol 11, Issue 1
ANGLE FOLLOW will make a spline label that follows the line.  ANGLE AUTO
will try to figure out the appropriate angle to put the text.  You can
only use FOLLOW on line features.
-Brian
From: geomoose-users-bounces at lists.sourceforge.net
[mailto:geomoose-users-bounces at lists.sourceforge.net] On Behalf Of Jim
Dahl
Sent: Tuesday, August 05, 2008 3:03 PM
To: geomoose-users at lists.sourceforge.net
Subject: Re: [Geomoose-users] Geomoose-users Digest, Vol 11, Issue 1
Are angle follow and angle auto similar?
geomoose-users-request at lists.sourceforge.net
Sent: Tuesday, August 05, 2008 1:36 PM
Subject: Geomoose-users Digest, Vol 11, Issue 1
Send Geomoose-users mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
	https://lists.sourceforge.net/lists/listinfo/geomoose-users
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
	geomoose-users-owner at lists.sourceforge.net
When replying, please edit your Subject line so it is more specific than
"Re: Contents of Geomoose-users digest..."
Today's Topics:
   1. GeoMoose and SDE (Jay Kapalczynski)
   2. Re: GeoMoose and SDE (Dan Little)
   3. Labeling (Jay Kapalczynski)
Message: 1
Date: Tue, 5 Aug 2008 11:03:25 -0500
From: Jay Kapalczynski <jkapalczynski at ci.maple-grove.mn.us>
Subject: [Geomoose-users] GeoMoose and SDE
To: <geomoose-users at lists.sourceforge.net>,
	<geomoose-developers at lists.sourceforge.net>
Message-ID:
<A1124B79D79DED4C94FAAA6FEB9AE64604052B1A at mg-ex2k.ci.maple-grove.mn.us>
Content-Type: text/plain; charset="us-ascii"
Can GeoMoose read and display SDE datasets...
If so how do you write the .map file?
Any thoughts / Examples of a .map file?
Thanks
Message: 2
Date: Tue, 5 Aug 2008 10:57:52 -0700 (PDT)
Subject: Re: [Geomoose-users] GeoMoose and SDE
To: Jay Kapalczynski <jkapalczynski at ci.maple-grove.mn.us>,
	geomoose-users at lists.sourceforge.net,
Message-ID: <636382.30392.qm at web51410.mail.re2.yahoo.com>
Content-Type: text/plain; charset="windows-1252"
Hey Jay,
This is more of a MapServer question.  But, I can say that is depends a
little on how you have SDE configured:
1) Configure SDE + ArcGIS Server to serve WMS - Then you access the
layers in GeoMOOSE just as you would any other WMS service.  This is
kinda handy because you can style the layer with the ESRI tools and use
SDE, but you get to side-step the headaches of using ArcIMS (and it's
replacements).
2) Store the SDE database in Oracle.  I'm not sure if MG is an Oracle
shop, but you can use SDE to store data in the Oracle SDO_GEOMETRY
format, which map server can also read.
3) Follow these directions:
http://www.maptools.org/ms4w/index.phtml?page=README_INSTALL.html#sde I
have no direct experience with following them so your mileage may vary a
bit.
----- Original Message ----
To: geomoose-users at lists.sourceforge.net;
Sent: Tuesday, August 5, 2008 11:03:25 AM
Can GeoMoose read and display SDE datasets?
Thanks
Message: 3
Date: Tue, 5 Aug 2008 13:35:50 -0500
Subject: [Geomoose-users] Labeling
Message-ID:
<A1124B79D79DED4C94FAAA6FEB9AE64604052B1E at mg-ex2k.ci.maple-grove.mn.us>
I have been successful labeling street centerlines using the ANGLE
FOLLOW in the .map File
This is being performed on a Shapefile Line feature
I also have a Polygon Feature that has a field that I am trying to
label....once again I need the text to follow the polygon
As you can see from the image the road names a following properly, but
the labels for the polygons are not following...
I tried the ANGLE FOLLOW on the Polygon and It will not draw..
Is there some other syntax that I have to put in the map file that will
force the text to follow the Polygon?
THANKS
LAYER # Maple Grove Streets Name
                    NAME Streets_Labels
                    DATA './GEOCODED_CENTERLINES2.shp'
                    STATUS DEFAULT
                    TYPE annotation
                    MAXSCALE 6000
                    MINSCALE 100
                    LABELITEM 'STREET_NAM'
                                LABELCACHE ON
                     CLASS
                       COLOR -1 -1 -1
                       LABEL
                                TYPE TRUETYPE
                                FONT vera_sans
                                ANGLE FOLLOW
                                POSITION AUTO
                                MAXSIZE 10
                                SIZE 8
                                MINSIZE 8
                                ANTIALIAS TRUE
                                COLOR 0 0 0
                                OUTLINECOLOR 255 255 192
                                BUFFER 2
                       END
                     END
  END # Maple Grove Streets Name
Name: not available
Type: image/jpeg
Desc: image001.jpg
This SF.Net email is sponsored by the Moblin Your Move Developer's
challenge Build the coolest Linux based applications with Moblin SDK &
win great prizes Grand prize is a trip for two to an Open Source event
anywhere in the world
http://moblin-contest.org/redirect.php?banner_id=100&url=/
Geomoose-users mailing list Geomoose-users at lists.sourceforge.net
End of Geomoose-users Digest, Vol 11, Issue 1
More information about the Geomoose-users mailing list
