[Geomoose-users] Numeric Values in TOC
Dan Little
danlittle at yahoo.com
Fri Aug 15 19:11:45 EDT 2008
Jay,
Mark had a solution for this last month:
A while ago I had a issue with identify results showing up
in scientific notation. Eg acres = 1.25000000000 e+2. I want to
have the acres to show up as 125.00
I found two solutions for that:
1) For numerical values instead of having [acres] used to
display your value, change it to [item name=”acres” precision=2].
Or
2) make sure you have your precision and scale set in your shapefile.
Mark Volz
GIS Specialist
Lyon County, MN
(507) 532-8218
----- Original Message ----
From: Jay Kapalczynski <jkapalczynski at ci.maple-grove.mn.us>
To: geomoose-users at lists.sourceforge.net; geomoose-developers at lists.sourceforge.net
Sent: Friday, August 15, 2008 12:41:40 PM
Subject: [Geomoose-users] Numeric Values in TOC
I am getting weird results in my TOC when I identify…
I am now using fields that are numeric…thin I need to
change something but don’t know what…
Thoughts on how to fix this?
Thanks
<tr>
<td
align="right">Acres:</td>
<td>[ACRES_POLY]</td>
</tr>
Skipped content of type multipart/related
More information about the Geomoose-users
