Actually, that will exclude anything with a 6 in it.
An easier way to go...
LAYER
CLASS
EXPRESSION '6'
# Leave this blank
END
CLASS
.... everything else ....
END
END
----- Original Message ----
From: "Fischer, Brian" <bfischer at houstonengineeringinc.com>
To: Jay Kapalczynski <jkapalczynski at ci.maple-grove.mn.us>; geomoose-users at lists.sourceforge.net; geomoose-developers at lists.sourceforge.net
Sent: Tuesday, August 19, 2008 4:41:09 PM
Subject: Re: [Geomoose-users] Expressions
I think that should do it.
Brian Fischer
Houston Engineering, Inc.
Maple Grove, MN
(763) 493-4522
[mailto:jkapalczynski at ci.maple-grove.mn.us]
2008 4:39 PM
To: Fischer, Brian; geomoose-users at lists.sourceforge.net;
Subject: RE:
Like this?
LAYER # Watermain_Pipe
#NAME Watermain_Pipe
DATA
'./watermain_pipes.shp'
STATUS DEFAULT
TYPE annotation
MAXSCALE 4000
MINSCALE 100
#LABELITEM 'DIAMETER'
LABELCACHE ON
CLASSITEM "DIAMETER"
CLASS
LABEL
EXPRESSION
/[^6]/
TYPE TRUETYPE
FONT vera_sans
ANGLE FOLLOW
POSITION AUTO
MAXSIZE 7
SIZE 7
MINSIZE 7
ANTIALIAS TRUE
COLOR 0 0 0
#OUTLINECOLOR 255 255 192
BUFFER 2
END
END
[mailto:bfischer at houstonengineeringinc.com]
2008 4:13 PM
To: Jay Kapalczynski;
Subject: RE:
Yep, you
just use a regular expression: /[^6]/
This is
a mapserver syntax.
Brian
Fischer
Inc.
Maple Grove,
MN
(763)
493-4522
From:geomoose-users-bounces at lists.sourceforge.net
[mailto:geomoose-users-bounces at lists.sourceforge.net] On Behalf Of Jay
Kapalczynski
Sent: Tuesday, August 19, 2008 4:08 PM
To: 'geomoose-users at lists.sourceforge.net';
'geomoose-developers at lists.sourceforge.net'
Subject: [Geomoose-users]
Expressions
Is there a way to form a NOT statement in the
expression…
To say for instance…show me all but EXPRESSION
“6”
Instead of having to write each one out that you want….say I
have pipe sizes 1-30 but 90% are 6 inches….jsut show the ones that are not 6
iches…
This should decrease the amount of labeling I have to
do
CLASS
LABEL
EXPRESSION "12"
TYPE TRUETYPE
FONT vera_sans
ANGLE FOLLOW
POSITION AUTO
MAXSIZE 7
SIZE 7
MINSIZE 7
ANTIALIAS TRUE
COLOR 0 0 0
BUFFER 2
END
END
CLASS
LABEL
EXPRESSION "16"
TYPE TRUETYPE
FONT vera_sans
ANGLE FOLLOW
POSITION AUTO
MAXSIZE 7
SIZE 7
MINSIZE 7
ANTIALIAS TRUE
COLOR 0 0 0
BUFFER 2
END
END
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20080820/af9085e6/attachment.html
