[Geomoose-users] jump to list (more stuff)
Jim Klassen
Jim.Klassen at ci.stpaul.mn.us
Mon Aug 25 10:50:55 EDT 2008
1) It is geomoose_configuration.js in the newer versions.
2) If the mapbook, geomoose_configuration.js or anything called by either is coded wrong the interface will fail to load. (Note XML included mapbooks will only cause themselves to fail to load if they are coded improperly).
>>> "Bob Basques" <Bob.Basques at ci.stpaul.mn.us> 08/23/08 11:55 AM >>>
All,
Just some more thoughts on how to get control of the jump to lists in a more flexible.
Ok, I found the jump to list in configuration.js. I assume I could make this into an include, but that doesn't seem like a failsafe system for some reason.
If the Mapbook could point to an external file name for the jump to list, then I get back the option of having different interface admins, handle their own jump to lists. But is this method bad in that it could be a single point of failure. will it crap out the loading of the interface if the external file is coded wrong?
This SF.Net email is sponsored by the Moblin Your Move Developer's challenge
Build the coolest Linux based applications with Moblin SDK & win great prizes
Grand prize is a trip for two to an Open Source event anywhere in the world
http://moblin-contest.org/redirect.php?banner_id=100&url=/
Geomoose-users mailing list
Geomoose-users at lists.sourceforge.net
https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users
