[Geomoose-users] Service Definition file, ability to override mapfile parameters?
Dan Little danlittle at yahoo.com
Tue Dec 2 09:18:31 EST 2008
For Mapserver > 5.0...
<map ..>
    <param name="map.layer[LAYERNAME].maxscaledenom" value="XXXXX"/>
</map>
This should work, you might need to check out the documentation here:
http://mapserver.gis.umn.edu/docs/reference/cgi/referencemanual-all-pages
Scroll about 2/3 the way down and you should find "Changing Mapfile Parameters via URL"
To: geomoose-users at lists.sourceforge.net
Sent: Tuesday, December 2, 2008 8:13:27 AM
Subject: [Geomoose-users] Service Definition file, ability to override mapfile parameters?
Is there a way when designating a “map” element
in the XML and specifying the file to also include parameters to override what
is specified in a map file?
For example, if I wanted one xml file to allow a maxscale
set to an override value so that I can see it at a higher scale than what is
specified in the map file.
Thanks,
Nelson
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20081202/997814de/attachment.html
More information about the Geomoose-users mailing list
