[Geomoose-users] identify point, modify label
Mark Volz
MarkVolz at co.lyon.mn.us
Fri Dec 5 16:38:50 EST 2008
I am having trouble with identifying a point file. I think it should be
working, as I basically copied another layers identify code. The only
difference is that now I am using a point file instead of a line or polygon
file.
Also I know in the html code we can truncate a value using item and precision
eg [item name="NORTHING" precision=4]. Can we do that in the on the label as
well?
Thanks
The layer portion in Identify.map
LAYER # Monuments Layer
NAME 'Monuments'
DATA 'Cadastral/Monuments.shp'
STATUS ON
TYPE POLYGON
#METADATA
# qstring_validation_pattern '.'
#END
TEMPLATE 'Cadastral/identify_Monuments.html'
TOLERANCE 2
END#layer
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20081205/c5f6487d/attachment.html
More information about the Geomoose-users
