[Geomoose-users] using the nexrad from iowa state
Mark Volz MarkVolz at co.lyon.mn.us
Wed Dec 10 11:11:43 EST 2008
Jim,
To reproject in your mapfile you will need the following:
MAP
    PROJECTION #UTM-14N  (the projection of your map)
      "init=epsg:26915"
    END
	LAYER  #IOWA ST NEXTRAD
	PROJECTION #UTM-15N  (the projection of the layer)
      	"init=epsg:26915"
    	END
Mark Volz
GIS Specialist
Lyon County, MN
(507) 532-8218
Message: 5
Date: Wed, 10 Dec 2008 08:33:47 -0600
Subject: [Geomoose-users] using the nexrad from iowa state
To: "geomoose-users at lists.sourceforge.net"
	<geomoose-users at lists.sourceforge.net>
Message-ID:
<5863BC6EA0494C498F8C7A389EF32E491CA8C1E0B4 at BannerExg.banner.bannerbkgs.com>
Content-Type: text/plain; charset="us-ascii"
I have moved the nexrad weather radar into my xml.  The example from the
statedemo has epsg number of 26915 but that puts the radar to the west of
where it should be.  The example is in utm15 and I'm in utm 14.  I have gone
out on the web and found other epsg numbers and used 26914 which is suppost
to be for the utm14 but whe I use anything other than utm15 the radar does
not appear on the screen.  Is there an other variable that needs to be
changed.
thanks
Jim Hagedorn
GIS Specialist
[cid:image001.gif at 01C95AA1.E32D2170]
Banner Associates, Inc.
409 22nd Avenue South * PO Box 298 * Brookings, South Dakota 57006
(605) 692-6342  *  Fax (605) 692-5714
www.bannerassociates.com<http://www.bannerassociates.com/>
More information about the Geomoose-users mailing list
