[Geomoose-users] Newer Versions
Dan Little danlittle at yahoo.com
Fri Feb 8 20:12:54 EST 2008
Jay,
You'll have to check the Service configuration in the Mapbook (.xml file).  That will have an input like
<input type="hidden" name="layer" value="Parks:PARK_ID"/>
You'll want to change that to:
<input type="hidden" name="layer" value="Parcles:PARCEL_ID"/>
Where PARCEL_ID is the name of the Parcel/PIN in the Shapefile/DBF.
----- Original Message ----
From: Jay Kapalczynski <jkapalczynski at ci.maple-grove.mn.us>
To: Bob Basques <Bob.Basques at ci.stpaul.mn.us>; geomoose-users at lists.sourceforge.net
Cc: geomoose-users at lists.sourceforge.net
Sent: Friday, February 8, 2008 3:45:24 PM
Subject: Re: [Geomoose-users] Newer Versions
 _filtered {font-family:"Cambria Math";panose-1:2 4 5 3 5 4 6 3 2 4;}
 _filtered {font-family:Calibri;panose-1:2 15 5 2 2 2 4 3 2 4;}
 _filtered {font-family:Tahoma;panose-1:2 11 6 4 3 5 4 4 2 4;}
 _filtered {font-family:Consolas;panose-1:2 11 6 9 2 2 4 3 2 4;}
/* Style Definitions */
 p.MsoNormal, li.MsoNormal, div.MsoNormal
	{margin:0in;margin-bottom:.0001pt;font-size:11.0pt;font-family:"Calibri", "sans-serif";}
a:link, span.MsoHyperlink
	{color:blue;text-decoration:underline;}
a:visited, span.MsoHyperlinkFollowed
	{color:purple;text-decoration:underline;}
p.MsoPlainText, li.MsoPlainText, div.MsoPlainText
	{margin:0in;margin-bottom:.0001pt;font-size:10.5pt;font-family:Consolas;}
p.MsoAcetate, li.MsoAcetate, div.MsoAcetate
	{margin:0in;margin-bottom:.0001pt;font-size:8.0pt;font-family:"Tahoma", "sans-serif";}
span.PlainTextChar
	{font-family:Consolas;}
span.BalloonTextChar
	{font-family:"Tahoma", "sans-serif";}
span.EmailStyle21
	{font-family:"Calibri", "sans-serif";color:#1F497D;}
.MsoChpDefault
	{font-size:10.0pt;}
 _filtered {margin:1.0in 1.0in 1.0in 1.0in;}
div.Section1
I got the Hieriarchal structure
working with this:
Simple use of the "Group
Title"
<group
title="COUNTY LAYERS" expand="false">
                                                <map
title="Parcels" default="True">
                                                <file>/ms4w/apps/GeoMOOSE/maps_statedemo/parcels/parcels_8bit.map</file>
                                                </map>
</group>
As for my select not working I
think that I found that the Proper Layer is not being identified to be selected….another
error is telling me that
it cannot find Parks in the Map
file…I have Parcels int eh Map file….so the select layer is not set right..
How do you set the layer to run
the select against….
THANKS ALL FOR THE HELP
Sent: Friday, February 08, 2008 11:59 AM
To: 'Bob Basques'; geomoose-users at lists.sourceforge.net
Subject: RE: [Geomoose-users] Newer Versions
I am excited to see any additional tools and
functionality I can get my hands on.
So what ever path it is to get this incorporated into
GeoMoose then I am gladly in...
Sorry for the loaded Email here…but good to hear from
someone….
I saw an example yesterday at the GITA meeting that
showed number one and two below.
I have not found any documentation on them, what code is
needed, and what pages need additional code.
Do you know where I could find an example of the code
need to impliment the Table Of Contents format:
Transportation
      Layer1
      Layer2
Water
      Layer1
      Layer2
1.       Hierarchal
Structure of the Table of Contents
2.       Data Inspector
(Pop-Ups)
3.       Create Point
4.       Buffer
5.       Address Labels
I have also heard of another tab that shows which layers
are selectable.  I am also looking for examples of this...I can create a
new tab but am having issues with incorporating the select function to work on
my data sets...
I just posted another entry on this issue.
Are there any examples or documentation out there on the
above mentioned functions.
Future Wish List
I am also interested in the capability of being able to
query multiple fields in a dataset.  Say Parcels with Assessing
data.  Build a query that grabs Single Family, Residential, and greater
than 150,000.
I added a search tab, drop down boxes etc. I am building
a string query but don’t know how to submit that to MapServer (even if possible)
and get GeoMoose to RETURN and SELECT those multiple records, then zoom to the
extent….
-----Original Message-----
From: Bob Basques [mailto:Bob.Basques at ci.stpaul.mn.us]
Sent: Friday, February 08, 2008 11:00 AM
To: geomoose-users at lists.sourceforge.net; Jay Kapalczynski
Jay,
To clarify what was in the Flash video, this was actually
an older branch of the development code of Moose.   That video was
demonstrating the capabilities of an older version than is currently in
production.
The feedback request was for gauging interest in
resurrecting the code branch and bringing it up to sync with the current
version in production.
The currently distributed version of GeoMoose was
developed from the feature heavy version in the flash video.
There was also a fair amount of code cleanup and streamlining between these
versions that would need to be implemented to bring it up to production
standards.
So it sounds like I could count you as a +1 for
proceeding down this path.
bobb
Bob Basques
GIS Systems Developer
City of Saint Paul, MN
GISmo
GeoMOOSE
>>> "Jay Kapalczynski"
<jkapalczynski at ci.maple-grove.mn.us> wrote:
I have been working with Geomooose on an off.  I
recently saw the Flash video and new tools that newer versions had.
1.       Hierarchal
2.       Data Inspector
(Pop-Ups)
3.       Create Point
4.       Buffer
5.       Address Labels
I guess my question is how do I find out what version I
am using and how do I upgrade to the newer versions without effecting the code
I have already written?
I am really excited to get my hands on this new
functionality.
THanks..
Jay
-----Inline Attachment Follows-----
This
SF.net
email
is
sponsored
by:
Microsoft
Defy
all
challenges.
Microsoft(R)
Visual
Studio
2008.
http://clk.atdmt.com/MRT/go/vse0120000070mrt/direct/01/
Geomoose-users
mailing
list
Geomoose-users at lists.sourceforge.net
https://lists.sourceforge.net/lists/listinfo/geomoose-users
      ____________________________________________________________________________________
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile.  Try it now.  http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
Skipped content of type multipart/related
More information about the Geomoose-users mailing list
