[Geomoose-users] [Geomoose-developers] Popups
Fischer, Brian
bfischer at houstonengineeringinc.com
Tue Mar 11 12:26:55 EDT 2008
Jay, try adding data="true" as an attribute. I think GeoMOOSE needs
that for some reason. Like the line below:
<map title="Fire Stations" default="true" popups="true" data="true">
Brian Fischer
Houston Engineering, Inc.
Maple Grove, MN
(763) 493-4522
-----Original Message-----
From: geomoose-developers-bounces at lists.sourceforge.net
[mailto:geomoose-developers-bounces at lists.sourceforge.net] On Behalf Of
Jim Klassen
Sent: Tuesday, March 11, 2008 11:20 AM
To: jkapalczynski at ci.maple-grove.mn.us
Cc: geomoose-developers at lists.sourceforge.net;
geomoose-users at lists.sourceforge.net
Subject: Re: [Geomoose-developers] [Geomoose-users] Popups
1) Is GeoMOOSE asking mapserver for the popup data? (You can see this in
Firebug under the net/all tab or in the console tab. Look for a call to
the parcel mapfile with mode=nquery) If not it is something in the
mapbook or configuration.js
2) If so, is that result valid XML? (Open the link from firebug in a new
tab and see if it parses OK)
On Tue, 2008-03-11 at 15:46 +0000, "Jay Kapalczynski" wrote:
> I am trying to get popups for my Parcels Layer...Cant seem to get it
to
> work
> The flag graphic (when hovered Over) says : "Popups unavaliable for
> this layer"
> THOUGHTS?
> In the demo.xml file
> In the Map File
> This is a look into the folder that holds the shapefile and map
> files....the xml files are there
> In the imagemap_record.xml File
> Header and footer xml
> City of Maple Grove
> Jason Kapalczynski
> GIS / IS
> Office 763.494.6282
> Fax: 763.494.6419
This SF.net email is sponsored by: Microsoft Defy all challenges.
Microsoft(R) Visual Studio 2008.
http://clk.atdmt.com/MRT/go/vse0120000070mrt/direct/01/
Geomoose-developers mailing list
Geomoose-developers at lists.sourceforge.net
https://lists.sourceforge.net/lists/listinfo/geomoose-developers
More information about the Geomoose-users
