[Geomoose-users] Buffer Tolerance
    Fischer, Brian
    bfischer at houstonengineeringinc.com
    Fri Mar 14 11:41:47 EDT 2008
The tolerance setting is actually in the select.map.  You can also read
more about it on the mapserver website in the mapfile reference guide.
For the parcels it should have been set to 0, but maybe it got changed.
This tolerance setting was giving me some problems when selecting and
buffering lines and points.  We need to get that worked out.
Brian Fischer
Houston Engineering, Inc.
Maple Grove, MN
(763) 493-4522
From: geomoose-users-bounces at lists.sourceforge.net
[mailto:geomoose-users-bounces at lists.sourceforge.net] On Behalf Of Jay
Kapalczynski
Sent: Friday, March 14, 2008 10:39 AM
To: geomoose-users at lists.sourceforge.net;
geomoose-developers at lists.sourceforge.net
Subject: [Geomoose-users] Buffer Tolerance
I assume there is a tolerance on the Buffer Select tool.....When I
select one parcel it grabs the neighboring parcel
I have been looking here for a tolerance setting but cant find anything
"buffer_select_countydemo.php"
Can someone point me in the correct direction?
Thanks
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20080314/7edae48d/attachment.html
More information about the Geomoose-users
