[Geomoose-users] Print service configuration issue
Clinton Olsen
clinton at co.emery.ut.us
Fri Mar 28 12:21:50 EDT 2008
I have the test-cgi-mapscript.py script working correctly now. I downloaded
the current version of MS4W and Pythoon 2.5.1, and ran the test and it looks
like it is working. After I reinstalled Geomoose, and ran the print service
on the example applications it looks like the script is working. When I try
to print it will bring up a PDF window, but then it will give me an Adobe
error window that says: File does not begin with %PDF. I am not sure if
anyone else has had this problem or not. Any help would be appreciated.
Thanks.
Clinton Olsen
IS/GIS Technician
-----Original Message-----
From: Jim Klassen [mailto:Jim.Klassen at ci.stpaul.mn.us]
Sent: Friday, March 28, 2008 9:07 AM
To: Clinton Olsen; geomoose-users at lists.sourceforge.net
Subject: Re: [Geomoose-users] Print service configuration issue
It looks like the mapscript module was compiled against Python 2.4 .x and
you are trying to use it with Python 2.5.1.
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20080328/1a7ff573/attachment.html
More information about the Geomoose-users
