[Geomoose-users] Print service configuration issue
Clinton Olsen
clinton at co.emery.ut.us
Fri Mar 28 15:07:46 EDT 2008
Do I need to have a folder called fpdf under the php folder? Right now the
FDF library is under C:\ms4w\apps\GeoMOOSE\webdocs\php.
Clinton Olsen
Emery County
IS/GIS Technician
(435) 381-5281
-----Original Message-----
From: Fischer, Brian [mailto:bfischer at houstonengineeringinc.com]
Sent: Friday, March 28, 2008 1:01 PM
To: Clinton Olsen; geomoose-users at lists.sourceforge.net
Cc: Jim Klassen
Subject: RE: [Geomoose-users] Print service configuration issue
Do you have the FDF library download and extracted to
C:\ms4w\apps\GeoMOOSE\webdocs\php\fpdf?
BTW...we have re-written the print service completely in PHP for the next
release of GeoMOOSE.
Brian Fischer
Houston Engineering, Inc.
Maple Grove, MN
(763) 493-4522
_____
From: geomoose-users-bounces at lists.sourceforge.net
[mailto:geomoose-users-bounces at lists.sourceforge.net] On Behalf Of Clinton
Olsen
Sent: Friday, March 28, 2008 11:22 AM
To: geomoose-users at lists.sourceforge.net
Cc: 'Jim Klassen'
Subject: Re: [Geomoose-users] Print service configuration issue
I have the test-cgi-mapscript.py script working correctly now. I downloaded
the current version of MS4W and Pythoon 2.5.1, and ran the test and it looks
like it is working. After I reinstalled Geomoose, and ran the print service
on the example applications it looks like the script is working. When I try
to print it will bring up a PDF window, but then it will give me an Adobe
error window that says: File does not begin with %PDF. I am not sure if
anyone else has had this problem or not. Any help would be appreciated.
Thanks.
Clinton Olsen
IS/GIS Technician
From: Jim Klassen [mailto:Jim.Klassen at ci.stpaul.mn.us]
Sent: Friday, March 28, 2008 9:07 AM
It looks like the mapscript module was compiled against Python 2.4 .x and
you are trying to use it with Python 2.5.1.
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20080328/430afa59/attachment.html
More information about the Geomoose-users
