[Geomoose-users] Print service configuration issue
Clinton Olsen clinton at co.emery.ut.us
Fri Mar 28 15:16:49 EDT 2008
Brian,
You rock.  I didn't see that step in the guide to setup the print service,
or maybe it is there and I didn't understand it.  I put the FDF folder under
the PHP folder and it worked like magic.  Thanks.
Clinton Olsen
Emery County
IS/GIS Technician
(435) 381-5281
-----Original Message-----
From: Fischer, Brian [mailto:bfischer at houstonengineeringinc.com]
Sent: Friday, March 28, 2008 1:13 PM
To: Clinton Olsen
Cc: geomoose-users at lists.sourceforge.net
Subject: RE: [Geomoose-users] Print service configuration issue
Yes you need to unless you switch the configuration variable in
Configuration.php
/*** Needed for PDF Printing... the location of FPDF ***/
$FPDF_LOCATION = './fpdf';
Brian Fischer
Houston Engineering, Inc.
Maple Grove, MN
(763) 493-4522
  _____
From: Clinton Olsen [mailto:clinton at co.emery.ut.us]
Sent: Friday, March 28, 2008 2:08 PM
To: Fischer, Brian
Do I need to have a folder called fpdf under the php folder?  Right now the
FDF library is under C:\ms4w\apps\GeoMOOSE\webdocs\php.
Clinton Olsen
Emery County
IS/GIS Technician
(435) 381-5281
Sent: Friday, March 28, 2008 1:01 PM
To: Clinton Olsen; geomoose-users at lists.sourceforge.net
Cc: Jim Klassen
Do you have the FDF library download and extracted to
C:\ms4w\apps\GeoMOOSE\webdocs\php\fpdf?
BTW...we have re-written the print service completely in PHP for the next
release of GeoMOOSE.
Brian Fischer
Maple Grove, MN
(763) 493-4522
  _____
From: geomoose-users-bounces at lists.sourceforge.net
[mailto:geomoose-users-bounces at lists.sourceforge.net] On Behalf Of Clinton
Olsen
Sent: Friday, March 28, 2008 11:22 AM
To: geomoose-users at lists.sourceforge.net
Cc: 'Jim Klassen'
Subject: Re: [Geomoose-users] Print service configuration issue
I have the test-cgi-mapscript.py script working correctly now.  I downloaded
the current version of MS4W and Pythoon 2.5.1, and ran the test and it looks
like it is working.  After I reinstalled Geomoose, and ran the print service
on the example applications it looks like the script is working.  When I try
to print it will bring up a PDF window, but then it will give me an Adobe
error window that says: File does not begin with %PDF.  I am not sure if
anyone else has had this problem or not.  Any help would be appreciated.
Thanks.
Clinton Olsen
IS/GIS Technician
From: Jim Klassen [mailto:Jim.Klassen at ci.stpaul.mn.us]
Sent: Friday, March 28, 2008 9:07 AM
It looks like the mapscript module was compiled against Python 2.4 .x and
you are trying to use it with Python 2.5.1.
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20080328/adacc5a1/attachment.html
More information about the Geomoose-users mailing list
