[Geomoose-users] multiple layer selection/thematic layers
problem
Brad Neuhauser
Brad.Neuhauser at state.mn.us
Wed May 7 17:37:50 EDT 2008
I can work on the How To (I even found my GeoMOOSE login).
Brad Neuhauser
GIS Specialist
Elections Division
Minnesota Office of the Secretary of State
651-201-1359
brad.neuhauser at state.mn.us
_____
From: Fischer, Brian [mailto:bfischer at houstonengineeringinc.com]
Sent: Wednesday, May 07, 2008 4:19 PM
To: Lee Meilleur; Bob Basques; geomoose-users at lists.sourceforge.net; Brad
Neuhauser
Subject: RE: multiple layer selection/thematic layers problem
Lee/Brad,
Very nice multiple layer pull down code. Do you want to contribute the code
and write a "How To" on the GeoMOOSE website?
As far as the layer ordering, there is a configuration setting in the
configuration.js file that is called MAP_MAPBOOK_ORDER. Do you have this
set to true or false? If it is set to false, change it to true and it
should get you what you want. If that doesn't work, what version of
GeoMOOSE are you running? It might be a bug. Let us know if you get it
working right.
There is a description about that setting at:
http://www.geomoose.org/moose/documentation/configuration-guides/configurati
on.js
<http://www.geomoose.org/moose/documentation/configuration-guides/configurat
ion.js> , go under the General Interface section.
-Brian
Brian Fischer
Houston Engineering, Inc.
Maple Grove, MN
(763) 493-4522
_____
From: Lee Meilleur [mailto:lee.meilleur at gis.leg.mn]
Sent: Wednesday, May 07, 2008 11:56 AM
To: Fischer, Brian; Bob Basques; geomoose-users at lists.sourceforge.net; 'Brad
Neuhauser'
Subject: multiple layer selection/thematic layers problem
A couple of things. First, Brad Neuhauser from Secretary of State wrote
some nifty code for a multiple layer selection pulldown. You can see it at
the link below. The map is being used for a bill that's up in one of the
House Committees (hf3293 if you're interested). For some reason, the
thematic layers towards the bottom always draw on top of everything else,
unless one spends the time to turn the layers off and on that are above the
thematic layers. Is there a way to make the map load and refresh so the
layers always draw correctly?
http://www.gis.leg.mn/geomoose/hf3293/
<http://www.gis.leg.mn/geomoose/hf3293/>
Thanks!
Lee Meilleur
LCC-GIS Office
Minnesota Legislature
100 Rev. Dr. MLK Jr Blvd.
55 State Office Building
St. Paul, MN 55155
651.296.0098 Fax: 651.297.3697
lee.meilleur at gis.leg.mn <mailto:lee.meilleur at gis.leg.mn>
http://www.gis.leg.mn <http://www.gis.leg.mn/>
NOTICE: E-mail correspondence to and from the Office of the Secretary of State of Minnesota may be public data subject to the Minnesota Data Practices Act and/or may be disclosed to third parties
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20080507/959247f8/attachment.html
More information about the Geomoose-users
