[Geomoose-users] multiple layer selection/thematic layers
problem
Lee Meilleur
lee.meilleur at gis.leg.mn
Thu May 8 15:55:34 EDT 2008
Bob,
I haven't had much feedback as of yet, this is the first app that's been made public. There were some problems with the opacity settings, so staffers using IE7 couldn't see some of the data (none of the thematic data was viewable). I set the opacity settings to "none", which took care of the problem. Is there a fix for using opacity with IE7?
I'll keep in touch regarding feedback.
Lee
-----Original Message-----
From: Bob Basques [mailto:Bob.Basques at ci.stpaul.mn.us]
Sent: Wednesday, May 07, 2008 10:00 PM
To: Lee Meilleur; bfischer at houstonengineeringinc.com; geomoose-users at lists.sourceforge.net; Brad.Neuhauser at state.mn.us
Subject: RE: multiple layer selection/thematic layers problem
Lee/Brad,
Very nice site, ditto what Brian said. I like seeing other business uses for GeoMoose beside our boring Public Works ones. Tell me, have you gathered any feedback from your customers about the mapping interface. Just wondering.
Thanks
bobb
>>> "Fischer, Brian" <bfischer at houstonengineeringinc.com> 05/07/08 4:19
>>> PM >>>
Lee/Brad,
Very nice multiple layer pull down code. Do you want to contribute the code and write a "How To" on the GeoMOOSE website?
As far as the layer ordering, there is a configuration setting in the configuration.js file that is called MAP_MAPBOOK_ORDER. Do you have this set to true or false? If it is set to false, change it to true and it should get you what you want. If that doesn't work, what version of GeoMOOSE are you running? It might be a bug. Let us know if you get it working right.
There is a description about that setting at: http://www.geomoose.org/moose/documentation/configuration-guides/configu
ration.js, go under the General Interface section.
-Brian
Brian Fischer
Houston Engineering, Inc.
Maple Grove, MN
(763) 493-4522
From: Lee Meilleur [mailto:lee.meilleur at gis.leg.mn]
Sent: Wednesday, May 07, 2008 11:56 AM
To: Fischer, Brian; Bob Basques; geomoose-users at lists.sourceforge.net;
'Brad Neuhauser'
Subject: multiple layer selection/thematic layers problem
A couple of things. First, Brad Neuhauser from Secretary of State wrote some nifty code for a multiple layer selection pulldown. You can see it at the link below. The map is being used for a bill that's up in one of the House Committees (hf3293 if you're interested). For some reason, the thematic layers towards the bottom always draw on top of everything else, unless one spends the time to turn the layers off and on that are above the thematic layers. Is there a way to make the map load and refresh so the layers always draw correctly?
http://www.gis.leg.mn/geomoose/hf3293/
<http://www.gis.leg.mn/geomoose/hf3293/>
Thanks!
Lee Meilleur
LCC-GIS Office
Minnesota Legislature
100 Rev. Dr. MLK Jr Blvd.
55 State Office Building
St. Paul, MN 55155
651.296.0098 Fax: 651.297.3697
http://www.gis.leg.mn <http://www.gis.leg.mn/>
More information about the Geomoose-users
