[Geomoose-users] SID Files
Fischer, Brian bfischer at houstonengineeringinc.com
Tue May 27 11:01:43 EDT 2008
Clinton,
I have used .sid's before directly in GeoMOOSE/MapServer.  Dan is right
they are support with the MS4W package.
I also use .ecw files quite a bit and found they perform slightly
better.  You still can't beat the performance of tiled imagery and
building overviews if you have the time and disk space to deal with
them. here's a snipit of the mapfile.  Also you should look at this page
http://mapserver.gis.umn.edu/docs/howto/raster_data and
http://mapserver.gis.umn.edu/docs/howto/optimizeraster
   #LAYER
   #  NAME ortho
   #  TYPE RASTER
   #  DATA wasecacc.sid
   #  OFFSITE  0 0 0
   #  STATUS  DEFAULT
  #END
-Hope that helps,
Brian
Brian Fischer
Houston Engineering, Inc.
Maple Grove, MN
(763) 493-4522
From: geomoose-users-bounces at lists.sourceforge.net
[mailto:geomoose-users-bounces at lists.sourceforge.net] On Behalf Of Dan
Little
Sent: Friday, May 23, 2008 12:52 PM
To: Clinton Olsen; geomoose-users at lists.sourceforge.net
Subject: Re: [Geomoose-users] SID Files
If I remember correctly, MS4W has built in support for SID's.
This should get you started, I believe other folks (I'm pretty sure City
of Saint Louis Park and some one else) are using SID and could possibly
share a mapfile with you.
----- Original Message ----
To: geomoose-users at lists.sourceforge.net
Sent: Friday, May 23, 2008 12:30:52 PM
Subject: [Geomoose-users] SID Files
I have several web applications that I have created using Geomoose.  I
would like to know how to add aerial photos to my web maps.  I have
severl SID files that are about 3 gigabits.  I need to know what the
steps and programs are that can get me started.  I have access to ARCGIS
and I can cut up the pictures using that program, but I need to know if
there is a simpler way.  Thanks.
Clinton Olsen
Emery County
IS/GIS Technician
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20080527/5b54399e/attachment.html
More information about the Geomoose-users mailing list
