[Geomoose-users] Print to PDF
Dan Little
danlittle at yahoo.com
Thu Nov 6 10:53:00 EST 2008
Yeah... I should really look at fixing that bug. Most of the WMS services support JPEG, so that's what I used. The other problem is that I do not believe that GD supports interlaced PNG's which is what the DRG's most likely are...
it may just require more testing and development on my part. This might be something I'm lamenting developing as I'd like to rollout GM 2.0beta before the Thanksgiving holiday.
From: "Fischer, Brian" <bfischer at houstonengineeringinc.com>
To: "Moore, Richard J" <richard.moore at mnsu.edu>; geomoose-users at lists.sourceforge.net
Sent: Thursday, November 6, 2008 9:45:48 AM
Subject: Re: [Geomoose-users] Print to PDF
Rick,
Your right I have never tried to
print the DRGs. Dan would know better than I would what your options might be
to get around this. It might involve code changes to print.php.
-Brian
[mailto:richard.moore at mnsu.edu]
Sent: Thursday, November 06, 2008 9:37 AM
To: Fischer, Brian; geomoose-users at lists.sourceforge.net
Subject: RE: [Geomoose-users] Print to PDF
Brian,
Thanks for the
information. I was able to create a configuration.php and print.php file
for each of the applications I have and then just changed the reference to the
print.php file in my application.xml file in htdocs.
My other question
now is; I am trying to get the LMIC’s USGS DRG’s to print but I get an
error when I try that. I have narrowed the culprit down to the
PrintWMS.map file in Resources. The aerial photos from LMIC come in as
jpeg’s and the printwms.map can handle because of the reference to this image
type(“wms_format” “image/jpeg”. However, the DRG’s are sent from LMIC as
PNG’s. The printwms.map cannot handle these unless I change the
“wms_format” to image/png. When I do this then the aerial photos don’t
print.
Is there a way to
adjust the printwms.map file to accept both of these formats from LMIC? I
would guess this would be a problem for everyone trying to print these.
Although maybe a lot of people have not tried to print out the drg’s on a map.
I have included
the printwms.map file for reference.
MAP
LAYER
NAME "wms_temp"
TYPE RASTER
STATUS DEFAULT
CONNECTION "url"
CONNECTIONTYPE WMS
METADATA
"wms_srs" ""
"wms_name" ""
"wms_server_version" ""
"wms_format" "image/jpeg"
END
END
END
Thanks,
Rick Moore
GIS Specialist
Water Resources
Center
184 Trafton
Science Center South
Minnesota State
University, Mankato
Mankato,
MN 56001
(507) 389-3267
[mailto:bfischer at houstonengineeringinc.com]
Sent: Wednesday, November 05, 2008 9:31 PM
To: Moore, Richard J; geomoose-users at lists.sourceforge.net
Rick,
This is one of the gotcha’s with
the demo’s. Currently there is only one configuration.php file for both
demo’s. I decided rather than create the extra files I would need to get
both working I would just leave it working for the county demo.
If you want to get the printing
working in both demo’s you would need to duplication the configuration.php and
print.php files and change the path in the configuration.php file to reference
the state_demo mapfiles. Then change the include file in the
print.php file to point to the other configuration file (something like
config_statedemo.php). I don’t have the files with me know but if you
need an example I could create one for you.
Hope this helps,
Brian
Sent: Wednesday, November 05, 2008 4:37 PM
To: 'geomoose-users at lists.sourceforge.net'
Subject: [Geomoose-users] Print to PDF
I am having problems with the
Print to PDF in the State Demo example.
If I run the Print to PDF in
the County Demo application it works perfectly but when I try it in the State
Demo application, I get this error message.
Available Printing Formats:
Warning: [MapServer Error]: msLoadMap():
(/ms4w/apps/geomoose/maps_countydemo/./parks/parks_8bit.map) in C:\ms4w\apps\GeoMOOSE\htdocs\php\print.php on line 177
Warning: Failed to open map file /ms4w/apps/geomoose/maps_countydemo/./parks/parks_8bit.map
Fatal error: Call to a member function setSize() on a non-object in C:\ms4w\apps\GeoMOOSE\htdocs\php\print.php on line 178
It seems like it is referencing a path location to the county demo
application as show by the path. I haven’t been able to find a location
that states where to look for the files when it prints.
Any assistance would be helpful since it seems like it is a
problem with the State Demo application since the County demo works. Also
I do have FPDF installed since the County Demo works for me.
Thanks,
Rick
Moore
GIS
Specialist
Water Resources Center
184 Trafton Science Center
South
Minnesota State University,
Mankato
Mankato, MN 56001
(507) 389-3267
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20081106/53650dce/attachment.html
More information about the Geomoose-users
