[Geomoose-users] Print to PDF - quick work around
Mark Volz
MarkVolz at co.lyon.mn.us
Thu Nov 6 10:56:27 EST 2008
Rick,
I was able to get the DRGS to print when I have the image format specified in
the map file as such.
MAP
NAME 'LMIC DRG'
#SIZE 800 650
STATUS ON
#EXTENT 521296 156295 674419 295679
UNITS FEET
IMAGETYPE JPEG
TRANSPARENT TRUE
WEB
Mark Volz
GIS Specialist
Lyon County, MN
(507) 532-8218
My other question now is; I am trying to get the LMIC's USGS DRG's to print
but I get an error when I try that. I have narrowed the culprit down to the
PrintWMS.map file in Resources. The aerial photos from LMIC come in as
jpeg's and the printwms.map can handle because of the reference to this image
type("wms_format" "image/jpeg". However, the DRG's are sent from LMIC as
PNG's. The printwms.map cannot handle these unless I change the "wms_format"
to image/png. When I do this then the aerial photos don't print.
Is there a way to adjust the printwms.map file to accept both of these
formats from LMIC? I would guess this would be a problem for everyone trying
to print these. Although maybe a lot of people have not tried to print out
the drg's on a map.
I have included the printwms.map file for reference.
MAP
LAYER
NAME "wms_temp"
TYPE RASTER
STATUS DEFAULT
CONNECTION "url"
CONNECTIONTYPE WMS
METADATA
"wms_srs" ""
"wms_name" ""
"wms_server_version" ""
END
END
END
Thanks,
Rick Moore
GIS Specialist
Water Resources Center
184 Trafton Science Center South
Minnesota State University, Mankato
Mankato, MN 56001
(507) 389-3267
richard.moore at mnsu.edu
From: Fischer, Brian [mailto:bfischer at houstonengineeringinc.com]
Sent: Wednesday, November 05, 2008 9:31 PM
To: Moore, Richard J; geomoose-users at lists.sourceforge.net
Subject: RE: [Geomoose-users] Print to PDF
Rick,
This is one of the gotcha's with the demo's. Currently there is only one
configuration.php file for both demo's. I decided rather than create the
extra files I would need to get both working I would just leave it working
for the county demo.
If you want to get the printing working in both demo's you would need to
duplication the configuration.php and print.php files and change the path in
the configuration.php file to reference the state_demo mapfiles. Then
change the include file in the print.php file to point to the other
configuration file (something like config_statedemo.php). I don't have the
files with me know but if you need an example I could create one for you.
Hope this helps,
Brian
From: Moore, Richard J [mailto:richard.moore at mnsu.edu]
Sent: Wednesday, November 05, 2008 4:37 PM
To: 'geomoose-users at lists.sourceforge.net'
Subject: [Geomoose-users] Print to PDF
I am having problems with the Print to PDF in the State Demo example.
If I run the Print to PDF in the County Demo application it works perfectly
but when I try it in the State Demo application, I get this error message.
Available Printing Formats:
Warning: [MapServer Error]: msLoadMap():
(/ms4w/apps/geomoose/maps_countydemo/./parks/parks_8bit.map) in
C:\ms4w\apps\GeoMOOSE\htdocs\php\print.php on line 177
Warning: Failed to open map file
/ms4w/apps/geomoose/maps_countydemo/./parks/parks_8bit.map in
Fatal error: Call to a member function setSize() on a non-object in
C:\ms4w\apps\GeoMOOSE\htdocs\php\print.php on line 178
It seems like it is referencing a path location to the county demo
application as show by the path. I haven't been able to find a location that
states where to look for the files when it prints.
Any assistance would be helpful since it seems like it is a problem with the
State Demo application since the County demo works. Also I do have FPDF
installed since the County Demo works for me.
Thanks,
Rick Moore
GIS Specialist
Mankato, MN 56001
(507) 389-3267
Name: Rick Moore (richard.moore at mnsu.edu).vcf
Type: text/x-vcard
Desc: Rick Moore (richard.moore at mnsu.edu).vcf
Message: 3
Date: Thu, 6 Nov 2008 09:45:48 -0600
From: "Fischer, Brian" <bfischer at houstonengineeringinc.com>
Subject: Re: [Geomoose-users] Print to PDF
To: "Moore, Richard J" <richard.moore at mnsu.edu>,
<geomoose-users at lists.sourceforge.net>
Message-ID:
<2EF6E1058C047344B4DE0FD141119167D1C9BA at hex01.houstonengineeringinc.com>
Content-Type: text/plain; charset="us-ascii"
Rick,
Your right I have never tried to print the DRGs. Dan would know better
than I would what your options might be to get around this. It might
involve code changes to print.php.
-Brian
Sent: Thursday, November 06, 2008 9:37 AM
To: Fischer, Brian; geomoose-users at lists.sourceforge.net
Brian,
Thanks for the information. I was able to create a configuration.php
and print.php file for each of the applications I have and then just
changed the reference to the print.php file in my application.xml file
in htdocs.
print but I get an error when I try that. I have narrowed the culprit
down to the PrintWMS.map file in Resources. The aerial photos from LMIC
come in as jpeg's and the printwms.map can handle because of the
reference to this image type("wms_format" "image/jpeg". However, the
DRG's are sent from LMIC as PNG's. The printwms.map cannot handle these
unless I change the "wms_format" to image/png. When I do this then the
trying to print these. Although maybe a lot of people have not tried to
print out the drg's on a map.
MAP
LAYER
NAME "wms_temp"
TYPE RASTER
STATUS DEFAULT
CONNECTION "url"
CONNECTIONTYPE WMS
METADATA
"wms_srs" ""
"wms_name" ""
END
END
END
Thanks,
Rick Moore
GIS Specialist
Mankato, MN 56001
(507) 389-3267
Rick,
one configuration.php file for both demo's. I decided rather than
create the extra files I would need to get both working I would just
leave it working for the county demo.
path in the configuration.php file to reference the state_demo
mapfiles. Then change the include file in the print.php file to point
to the other configuration file (something like config_statedemo.php).
I don't have the files with me know but if you need an example I could
create one for you.
Hope this helps,
Brian
perfectly but when I try it in the State Demo application, I get this
error message.
that states where to look for the files when it prints.
the State Demo application since the County demo works. Also I do have
FPDF installed since the County Demo works for me.
Thanks,
Rick Moore
GIS Specialist
Mankato, MN 56001
(507) 389-3267
This SF.Net email is sponsored by the Moblin Your Move Developer's challenge
Build the coolest Linux based applications with Moblin SDK & win great prizes
Grand prize is a trip for two to an Open Source event anywhere in the world
http://moblin-contest.org/redirect.php?banner_id=100&url=/
Geomoose-users mailing list
Geomoose-users at lists.sourceforge.net
https://lists.sourceforge.net/lists/listinfo/geomoose-users
End of Geomoose-users Digest, Vol 14, Issue 20
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20081106/6cd98acb/attachment.html
More information about the Geomoose-users
