[Geomoose-users] PDF Printing [Scanned]
Dale Harris dharris at regisresources.com
Sun Oct 5 23:32:28 EDT 2008
Should all layers be set up to come in as WMS?
Sent: Friday, 3 October 2008 10:15 PM
To: Dale Harris; geomoose-users at lists.sourceforge.net
Subject: Re: [Geomoose-users] PDF Printing [Scanned]
Is your Roads layer coming in as WMS?
I'm thinking you're correct on the transparency issue.
----- Original Message ----
To: geomoose-users at lists.sourceforge.net
Sent: Friday, October 3, 2008 2:35:23 AM
Subject: [Geomoose-users] PDF Printing
I have probably just not found the right configuration line but whenever
I print using the php scripts it creates a nice looking pdf but with
only the top layer. I can manually force the opacity to 50 and this
shows all layers (but very ugly) so I think it just a transparency layer
effect. Can someone point me in the right direction?
Please see the attached screenshots.
Cheers,
Dale Harris
GIS Manager
Regis Resources
Ground Floor
62 Colin Street
West Perth WA 6005
Direct Line (08) 9442 2207
Fax: (08) 9442 2290
Email: dharris at regisresources.com
This message may contain privileged and confidential information.  If you are not the intended recipient of this message, you are notified that any use, dissemination, distribution or reproduction of this message is strictly prohibited.  If you receive this message in error, please notify Regis Resources Limited immediately.
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20081006/25d7a86e/attachment.html
More information about the Geomoose-users mailing list
