[Geomoose-users] [Geomoose-developers] GeoMoose 1.6 IE7 Bug
Jay Kapalczynski
jkapalczynski at ci.maple-grove.mn.us
Tue Oct 7 15:01:05 EDT 2008
Cool…thanks guys…..dont mean to sound like I am impatient….it gets done when it gets done….
Although I am having issues with printing…there was another section that you guys covered (reports). Is this different then printing the map with the fields at the bottom?
Just thought this was going to work out of the box…
Any thoughts?
Thanks….
Sent: Tuesday, October 07, 2008 9:53 AM
To: Jay Kapalczynski; Fischer, Brian; Nelson Soto; geomoose-users at lists.sourceforge.net; geomoose-developers at lists.sourceforge.net
Subject: Re: [Geomoose-developers] [Geomoose-users] GeoMoose 1.6 IE7 Bug
It will be a minor file fix if you're already at 1.6. All you should need to swap out is GeoMOOSE.js and main.js.
----- Original Message ----
From: Jay Kapalczynski <jkapalczynski at ci.maple-grove.mn.us>
To: "Fischer, Brian" <bfischer at houstonengineeringinc.com>; Dan Little <danlittle at yahoo.com>; Nelson Soto <NSoto at plotplans.com>; "geomoose-users at lists.sourceforge.net" <geomoose-users at lists.sourceforge.net>; "geomoose-developers at lists.sourceforge.net" <geomoose-developers at lists.sourceforge.net>
Sent: Tuesday, October 7, 2008 9:46:43 AM
Subject: RE: [Geomoose-developers] [Geomoose-users] GeoMoose 1.6 IE7 Bug
Thanks….I was not sure if that was the same one…..
What kind of time frame?
Is it going to be just a file that we replace of are we going to have to replace a bunch of files….
Again just don’t want to rewrite my code…
Thanks for all your help guys….
Might have a few questions with the new folder and file format in v1.6….but sure I will be able to track them down….
From: Fischer, Brian [mailto:bfischer at houstonengineeringinc.com]
Sent: Tuesday, October 07, 2008 9:43 AM
To: Jay Kapalczynski; Dan Little; Nelson Soto; geomoose-users at lists.sourceforge.net; geomoose-developers at lists.sourceforge.net
You found the known bug. Dan is working on a fix and when it is fixed we will release a 1.6.1 version.
From: Jay Kapalczynski [mailto:jkapalczynski at ci.maple-grove.mn.us]
Sent: Tuesday, October 07, 2008 9:41 AM
To: Fischer, Brian; Dan Little; Nelson Soto; geomoose-users at lists.sourceforge.net; geomoose-developers at lists.sourceforge.net
I just installed v1.6 with the latest version of Map Server.
When I open the test apps in IE no tool bar buttons show up
Its fine in Firefox…
Thoughts….
Sent: Wednesday, September 24, 2008 8:34 AM
To: Dan Little; Nelson Soto; geomoose-users at lists.sourceforge.net; geomoose-developers at lists.sourceforge.net
No, it’s probably before you fixed that bug. After you get the latest code changes into trunk I will package up a 1.6.1 version.
If anyone else finds any bugs, let us know and we might be able to address them in a 1.6.1 version.
Thanks,
Brian
Brian Fischer
Houston Engineering, Inc.
Maple Grove, MN
(763) 493-4522
Sent: Wednesday, September 24, 2008 7:55 AM
To: Nelson Soto; geomoose-users at lists.sourceforge.net; geomoose-developers at lists.sourceforge.net
Brian,
Is 1.6 operating off of the latest code in Trunk? This was a bug that was fixed for the MMCD application.
To: geomoose-users at lists.sourceforge.net; geomoose-developers at lists.sourceforge.net
Sent: Wednesday, September 24, 2008 7:52:11 AM
Subject: [Geomoose-users] GeoMoose 1.6 IE7 Bug
After extracting the new version and checking out the demos, neither pulls up their toolbar under IE7 and I get an e Javascript error on line 692. Likely the error is somewhere before hand or as a result of something else because line 692 is ʽhttp.send(postData);}ʼ
Itʼs worth noting that Firefox 3 works correctly so far.
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20081007/965dd486/attachment.html
More information about the Geomoose-users
