[Geomoose-users] Imagemaps + GeoMoose
Bob Basques Bob.Basques at ci.stpaul.mn.us
Tue Oct 7 15:05:41 EDT 2008
Matej,
Take a look at these examples, GeoMoose 1.4:
The trick is to have the XML template files handy for sending the Imagemap instead of the raster image from MapServer.
MAPFILE:
##  Example ImageMapCall:
##	http://dragonslayer.ci.stpaul.mn.us/cgi-bin/mapserv?
##		map=amanda02.map&
##		imgext=593420.362790+170048.359702+593673.612838+170254.118302&
##		imgxy=399.5+324.5&
##		zoom=-2
MAP
  NAME 'test'
  SIZE 800 650
  STATUS ON
  ##IMAGECOLOR 254 254 254
  ##EXTENT 540000 135000 600000 175000
  EXTENT 593133.398829 170094.734526 593893.148973 170712.010326
  UNITS FEET
  ##FONTSET view.fonts
  SYMBOLSET mon.symbols
  TRANSPARENT TRUE
  IMAGETYPE PNG
  LAYER
    METADATA
      "ows_title" "layer_0"
      "gml_include_items" "all"
    END
     NAME 'monuments-cogo'
    DATA 'SURVEY/2006_00/COGO/Monuments-cogo'
    GROUP 'monuments'
    STATUS DEFAULT
    TYPE POINT
    LABELITEM 'OLD'
    CLASS
      NAME 'COGO'
      OUTLINECOLOR 0 0 0
      COLOR 255 200 200
      SIZE 10
      SYMBOL 'square'
      OVERLAYOUTLINECOLOR 0 0 0
      OVERLAYCOLOR 0 0 0
      OVERLAYSIZE 5
      OVERLAYSYMBOL 'circle'
      ##LABEL
        ##FORCE TRUE
        ##COLOR 255 200 200
        ##OUTLINECOLOR 0 0 0
        ##SIZE LARGE
        ##WRAP ' '
      ##END
    END
    ##HEADER   '../../imagemap/monuments_header.html'
    TEMPLATE 'SURVEY/2006_00/COGO/Monuments-cogo_record.xml'
    FOOTER   'SURVEY/2006_00/COGO/Monuments-cogo_footer.xml'
  END
END ## end Map
HEADER.XML
<Xxml version="1.0"?>
<Xxml-stylesheet type="text/xsl" href="[XSL_LOCATION]"?>
<imagemap>
	<name>[MAP_ID]</name>
	<style name="Monuments"><![CDATA[
	div.Monuments {
		background: #AAAAFF;
		border: solid 3px #DDDDDD;
	div.Monuments div#title {
		background: #007733;
		color: white;
		font-weight: bold;
		<title>
			<attr name="background" value="#073"/>
			<attr name="fontWeight" value="bold"/>
			<attr name="color" value="white"/>
		</title>
		<contents>
			<attr name="background" value="#AAF"/>
		</contents>
	</style>
RECORD.XML (there is a sample "Monument.shp" sample file in the GeoMoose distro that shows the column names)
<popup class="Monuments" shape="circle" coords="[shpxy xf="," proj=image],15" displayxy="[shpxy xf="," proj=image]">
	<title>Monument</title>
	<item title="COGO:">[COGO]</item>
	<item href="http://survey.ci.stpaul.mn.us/tmp/[HYPERLINK]">Metadata</item>
	<item href="http://survey.ci.stpaul.mn.us/tmp/[TIES]">Ties for MON #[OLD]</item>
	<item href="http://survey.ci.stpaul.mn.us/tmp/[PHOTO]">Photos for MON #[OLD]</item>
</popup>
FOOTER.XML
</imagemap>
bobb
>>> "Matej" <matej at matnet.net> 10/07/08 10:05 AM >>>
Hello,
I am still having that issue with Imagemaps and Geomoose. Could you please
send me some code snippets as you wrote me you can?
I am desperately looking for some examples and even popups documentation
(can I achieve the goal I want with them?) that was on the old web site is
missing.
Thank you for your reply in advance,
Matej Serc
matej at matnet.net
More information about the Geomoose-users mailing list
