[Geomoose-users] roads layer is not transparent in IE6 AGG
renderer
Dan Little
danlittle at yahoo.com
Tue Oct 14 12:01:07 EDT 2008
Complain to Microsoft. :)
AGG renders PNGs in a way that is not compatible with IE6. This is not a GeoMOOSE problem, this is not a Mapserver problem, this is a Microsoft problem, and a problem of using 7 year old software.
----- Original Message ----
To: geomoose-users at lists.sourceforge.net
Sent: Tuesday, October 14, 2008 10:57:37 AM
Subject: [Geomoose-users] roads layer is not transparent in IE6 AGG renderer
When using IE6 as a client it appears that my roads layer is
not transparent, Instead I see a gray background under my roads. I am
using AGG as a rendered for roads. Is this a problem with IE 6, a bug
with AGG, or could something be incorrect with my .map file?
Also,
A while ago I noticed that when using the AGG reindeer the legend
text does not display. Has anyone found a workaround for this? Has
it been fixed in 1.6 (I haven’t tried 1.6 yet).
Thanks
MAP
NAME
'roads'
SIZE
800 650
STATUS
ON
UNITS
FEET
Projection
# Lyon County Coordinates
"proj=lcc"
'lat_1=44.25'
'lat_2=44.58333333333334'
'lat_0=44.19555555555555'
'lon_0=-95.85000000000001'
'x_0=152400.3048006096'
'y_0=30480.06096012192'
'a=6378559.758'
'b=6357173.65471281'
"units=ft"
"no_defs"
END
#projection
FONTSET
'../fonts/fontset.list'
SYMBOLSET
'../symbols/symbol.sym'
TRANSPARENT
TRUE
#IMAGETYPE
PNG
#IMAGETYPE
PNG #STANDARD OUTPUT TO PNG
##########ATTEMPT
TO HOOK INTO AGG RENDERER
OUTPUTFORMAT
NAME
'AGG_PNG24'
DRIVER
AGG/PNG
IMAGEMODE
RGB
END
#HOOK TO AGG RENDERER
QUERYMAP
STATUS
ON
STYLE
SELECTED
END
WEB
INCLUDE "/ms4w/apps/GeoMOOSE/maps_lyondemo/web_config.map"
END
LEGEND
STATUS
ON
END
LAYER
MAP
NAME
'roads'
SIZE
800 650
STATUS
ON
UNITS
FEET
Projection
END
#projection
FONTSET
SYMBOLSET
TRANSPARENT
TRUE
#IMAGETYPE
PNG
#IMAGETYPE
##########ATTEMPT
OUTPUTFORMAT
NAME
'AGG_PNG24'
DRIVER
AGG/PNG
IMAGEMODE
RGB
END
QUERYMAP
STATUS
ON
STYLE
SELECTED
END
WEB
END
LEGEND
STATUS
ON
END
LAYER
Mark Volz
GIS Specialist
Lyon County, MN
(507) 532-8218
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20081014/d2783b81/attachment.html
More information about the Geomoose-users
