[Geomoose-users] Service Types XML
Dan Little
danlittle at yahoo.com
Fri Oct 24 10:28:34 EDT 2008
There is an intentional lack of documentation there, and that's because it's a freakin' hack.
What happens when you return stuff from a service is this:
1) If it returns mapbook XML, then it processes it as if you've loaded another mapbook, it can turn layers on, update them, etc.
2) If it returns HTML, it displays the HTML in the DIV, and then takes commands from the <moose:mapbook>, it uses the different name space in order to get the ease of HTML templating and get the power needed to do two way communications between the Javascript client and the server-side services.
To: Nelson Soto <NSoto at plotplans.com>; geomoose-users at lists.sourceforge.net; geomoose-developers at lists.sourceforge.net
Sent: Friday, October 24, 2008 8:58:35 AM
Subject: Re: [Geomoose-users] Service Types XML
Ok, well if it seems there is no
up-to-date information regarding this then how about the moose: tags returned
from services?
[mailto:NSoto at plotplans.com]
Sent: Wednesday, October 22, 2008
2:52 PM
To: geomoose-users at lists.sourceforge.net; geomoose-developers at lists.sourceforge.net
Service Types XML
Is there an up-to-date Mapbook Reference
guide? I would like to see all of the acceptable input types at the moment.
2:31 PM
To: Nelson Soto;
Service Types XML
The "types" are actually deprecated.
They used to imply how the search results were called and processed. The
only type that is honoured any more is "xml-post" which you can see
an example of operation in the Print service, which actually posts XML to
print.php for output.
1:29:00 PM
Subject: [Geomoose-users] Service
Types XML
I am looking at the service definition located at
GeoMoose’s website. http://www.geomoose.org/moose/index.php?option=com_content&task=view&id=14&Itemid=29
I am trying to investigate the different parameters;
particularly ‘type’. I am looking at the Select Feature Service and
notice the type is “inspect-search”. What is this? Are there more
types than the 3 displayed on the site? Any help is appreciated..
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20081024/5ebd1499/attachment.html
More information about the Geomoose-users
