[Geomoose-users] Projection
Fischer, Brian bfischer at houstonengineeringinc.com
Fri Oct 24 14:46:11 EDT 2008
Here's an example mapfile. It projects a WMS service in UTM 15 to
McLeod, MN coordinate system.
MAP
  NAME 'DOQ'
  SIZE 800 650
STATUS ON
EXTENT 521296 156295 674419 295679
UNITS FEET
  IMAGETYPE JPEG
  TRANSPARENT TRUE
  WEB
  	INCLUDE "../web_config.map"
END
 Projection  #McLeod County Coordinates
        "proj=lcc"
        "lat_1=45.799999999999997000"
        "lat_2=44.916666666666657000"
        "lat_0=44.456111111111113000"
        "lon_0=-94.633333333333340000"
        "x_0=152400.3048"
        "y_0=30480.06096"
        "a=6378414.3689999999"
        "b=6357028.7531746011"
        "units=ft"
        "no_defs"
   END
#http://geoint.lmic.state.mn.us/cgi-bin/wms?LAYERS=fsa&SERVICE=WMS&a
mp;VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=applicati
on/vnd.ogc.se_inimage&FORMAT=image/jpeg&SRS=EPSG:26915&BBOX=
%MINX%,%MINY%,%MAXX%,%MAXY%&WIDTH=%WIDTH%&HEIGHT=%HEIGHT%
  # This layer comes from LMIC and is enabled only when the map scale
  # is at or above 1:24,000
  LAYER
    NAME         lmic_doq
    TYPE         RASTER
    #OFFSITE      0 0 0
    STATUS       DEFAULT
    CONNECTIONTYPE WMS
    CONNECTION "http://geoint.lmic.state.mn.us/cgi-bin/wms?"
    #MINSCALE      1000 # only display down to this scale
    #MAXSCALE     24000
    METADATA
      "wms_srs" "EPSG:26915"
      "wms_name" "doq"
      "wms_server_version" "1.1.1"
      "wms_format" "image/jpeg"
      "wms_styles" ""
      "wms_exceptions" "application/vnd.ogc.se_inimage"
    END
    PROJECTION
      "init=epsg:26915"
    END
  END
END
Brian Fischer
Houston Engineering, Inc.
Maple Grove, MN
(763) 493-4522
-----Original Message-----
Sent: Friday, October 24, 2008 12:05 PM
To: Heather Wirth; geomoose-users at lists.sourceforge.net
Subject: Re: [Geomoose-users] Projection
Hi Heather,
Is the data WMS layer, shapefile?
The process will be rather the same, but I'd rather give you specific
help instead of writing a tutorial on reprojection. :-)
----- Original Message ----
> From: Heather Wirth <HWIRTH at co.benton.mn.us>
> To: geomoose-users at lists.sourceforge.net
> Sent: Friday, October 24, 2008 11:31:39 AM
> Subject: [Geomoose-users] Projection
> I have, what I hope, is a quick question.  To date, I haven't paid
much
> attention to how to reproject a layer.
> So far, I have used only layers that use our county coordinate system.
> Now, I want to include a layer that uses UTM.  It seems like I have
seen
> a fairly simple way of doing this, but I can't find it.  Can someone
> please help?
> Thank you
> This SF.Net email is sponsored by the Moblin Your Move Developer's
challenge
> Build the coolest Linux based applications with Moblin SDK & win great
prizes
> Grand prize is a trip for two to an Open Source event anywhere in the
world
> http://moblin-contest.org/redirect.php?banner_id=100&url=/
> Geomoose-users mailing list
> Geomoose-users at lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geomoose-users
challenge
prizes
world
More information about the Geomoose-users mailing list
