[Geomoose-users] GeoMoose Services and output options.
Nelson Soto
NSoto at plotplans.com
Wed Oct 29 09:38:50 EDT 2008
Excellent; As always, you are a great help. Thank you.
Sent: Wednesday, October 29, 2008 9:26 AM
To: Nelson Soto; geomoose-developers at lists.sourceforge.net;
geomoose-users at lists.sourceforge.net
Subject: Re: [Geomoose-users] GeoMoose Services and output options.
They don't need to be used. GeoMOOSE will handle whatever return type
you throw at it.
The XML mode was originally the only return type GeoMOOSE supported.
There are provisions in that return type to return HTML-like tables in
XML. Folks found this not flexible enough so the HTML, text, and CSV
formats were added.
To: geomoose-developers at lists.sourceforge.net;
Sent: Wednesday, October 29, 2008 7:33:46 AM
Subject: [Geomoose-users] GeoMoose Services and output options.
I have done some work for my own services and naturally have noticed
there are typically xml and html output modes. I understand why the html
exists, but I am curious if the XML ever gets used? For instance, if I
modify the output of the HTML, should I also be replicating these edits
for the XML output as well? If so, when do these get used?
Thanks.
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20081029/7996c7a2/attachment.html
More information about the Geomoose-users
