[Geomoose-users] Attribute Searching via CGI in GeoMoose.
Nelson Soto
NSoto at plotplans.com
Thu Oct 30 16:13:11 EDT 2008
For some reason ever so randomly I will select to zoom to a parcel and
the feature will highlight and then be gone... if I use Firebug to look
at the html, I notice the Highlight-Loading layer is still inside and on
top of all other img's in the Map Div. I can never consistently make it
repeat but it is so often now that I have to completely start a new site
from scratch. The only problem is taking the county demo and simply
swapping my data out in and running the PIN search on my parcels also
does this. Maybe 1 out of every 8 clicks. Typically but not always it
will be the first one. I have re-installed ms4w and geomoose and have
only kept my maps, I have not even bothered to reconstruct my services
or interface until I can clear this issue up... Also, if I attribute
search a parcel that is '8_0' it refuses to highlight at all. It is
selectable by the feature selection and buffer however????
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20081030/8de3de36/attachment.html
More information about the Geomoose-users
