[Geomoose-users] GeoMoose apache and IIS
Dan Little
danlittle at yahoo.com
Tue Sep 9 15:24:56 EDT 2008
Jay,
The problem really occurs if Apache and IIS are running on the same port. You may want to see if you can switch to all IIS as an administrative step. Having both Apache and IIS means you need to contend with multiple server configuration pieces and means more potential security breaches.
-Duck
----- Original Message ----
From: Jay Kapalczynski <jkapalczynski at ci.maple-grove.mn.us>
To: "Fischer, Brian" <bfischer at houstonengineeringinc.com>; "geomoose-developers at lists.sourceforge.net" <geomoose-developers at lists.sourceforge.net>; "geomoose-users at lists.sourceforge.net" <geomoose-users at lists.sourceforge.net>
Sent: Friday, September 5, 2008 9:10:38 AM
Subject: [Geomoose-users] GeoMoose apache and IIS
Brian mentioned on the GeoMOOSE web page that you can NOT
run Apache and IIS at the same time
Are you referring to issues that might arise on a server? I
am currently running IIS and Apache on my local computer and it runs great.
I am using Apache for the GeoMOOSE stuff and passing
variables to IIS which allows me to code in ASP.net etc
Have you seen issues related to running both? If so what
should I be aware of?
Skipped content of type multipart/related
More information about the Geomoose-users
