[Geomoose-users] GeoMoose apache and IIS
Dan Little danlittle at yahoo.com
Wed Sep 10 12:58:34 EDT 2008
Yeah, to remove IIS, you'd need to migrate your ASP pages to PHP.
This is probably something Brian/I could be contracted to do if it was something you wanted for a production application.
----- Original Message ----
From: Jay Kapalczynski <jkapalczynski at ci.maple-grove.mn.us>
To: Dan Little <danlittle at yahoo.com>; "Fischer, Brian" <bfischer at houstonengineeringinc.com>; "geomoose-developers at lists.sourceforge.net" <geomoose-developers at lists.sourceforge.net>; "geomoose-users at lists.sourceforge.net" <geomoose-users at lists.sourceforge.net>
Sent: Wednesday, September 10, 2008 8:10:47 AM
Subject: RE: [Geomoose-users] GeoMoose apache and IIS
Ok that makes sense….I am simply hitting the IIS portion to run
ASP pages from GeoMoose.  Grabbing PIDs etc and updating SQL databases.
I simply changed the port number on my IIS to something other
than port 80, which GeoMoose defaults to.
The only reason I am running apache is to show that it can be
run without IIS.  Using apache I can hit Access Databases and update those with
SQL statements but its harder without being able to run ASP pages.
I intend to run IIS completely but want to create the
application in a completely free environment first…just because I can I guess….then
simply switch over to IIS.
Thanks for your input guys
Jay
[mailto:danlittle at yahoo.com]
Sent: Tuesday, September 09, 2008 2:25 PM
To: Jay Kapalczynski; Fischer, Brian;
geomoose-developers at lists.sourceforge.net; geomoose-users at lists.sourceforge.net
Subject: Re: [Geomoose-users] GeoMoose apache and IIS
Jay,
The
problem really occurs if Apache and IIS are running on the same port.  You
may want to see if you can switch to all IIS as an administrative step.
 Having both Apache and IIS means you need to contend with multiple server
configuration pieces and means more potential security breaches.
-Duck
To: "Fischer, Brian" <bfischer at houstonengineeringinc.com>;
Sent: Friday, September 5, 2008 9:10:38 AM
Subject: [Geomoose-users] GeoMoose apache and IIS
Brian
mentioned on the GeoMOOSE web page that you can NOT run Apache and IIS at the
same time
Are
you referring to issues that might arise on a server? I am currently running
IIS and Apache on my local computer and it runs great.
I
am using Apache for the GeoMOOSE stuff and passing variables to IIS which
allows me to code in ASP.net etc
Have
you seen issues related to running both?  If so what should I be aware of?
Skipped content of type multipart/related
More information about the Geomoose-users mailing list
