[Geomoose-users] Limit Identify Result
Dan Little
danlittle at yahoo.com
Thu Aug 6 15:40:11 EDT 2009
This the first request for the feature that I've heard, so no, it's not implemented. It wouldn't be a difficult add-on to either GM1.6.X or GM2.0 ... shall I consider the option officially requested?
>From: Jessica Fendos <Jessica.Fendos at state.mn.us>
>To: Brent Fraser <bfraser at geoanalytic.com>; Dan Little <danlittle at yahoo.com>
>Cc: geomoose-users at lists.sourceforge.net
>Sent: Thursday, August 6, 2009 2:33:21 PM
>Subject: Re: [Geomoose-users] Limit Identify Result
>Thanks Dan for the quick response. I know GeoMoose 2.0 is built on MapServer and OpenLayers. Will 2.0 take care of identify limit at this time? Appreciate your time!
>Jessica
>>>> Dan Little <danlittle at yahoo.com> 8/6/2009 2:27 PM >>>
>That add-on is something chameleon implemented. For identify functionality GeoMOOSE 1.6.X uses MapServer directly, so if it's not a native-MapServer supported function it will not work with GeoMOOSE 1.6.X
>>Sent: Thursday, August 6, 2009 2:23:20 PM
>>Thanks Brent:
>>I was able to limit the identify result using this metadata tag in Chameleon (another add-on to MapServer) so was hoping I can do the same in GeoMoose.... Suggestions anyone?
>>Jessica
>>>>> Brent Fraser <bfraser at geoanalytic.com> 8/6/2009 2:10 PM >>>
>>Jessica,
>> I don't think "query_limit" has been implemented in Mapserver yet
>>(http://trac.osgeo.org/mapserver/ticket/2424). The only option I can think of
>>is to do some PHP (or other scripting language) programming, similar to GM's
>>select.php and limit the returned results there.
>> But you might want to ask the question on the Mapserver-users email list.
>>Best Regards,
>>Brent Fraser
>>Jessica Fendos wrote:
>>> Hi list:
>>> I am using GeoMoose 1.6.1. I have several point layers (employers by
>>> industry) that I would like to display in the mapping interface. Due to
>>> InfoUSA data restriction, I would like to limit the display of records
>>> resulting from the "Identify" tool to 5.
>>> I added the following
>>> *METADATA
>>> "query_limit" "5"
>>> END*
>>> to this layer in identify.map (under maps_statedemo) and employer.map
>>> (under maps_statedemo/employer) but it does not seem to have any effect.
>>> Is there a way for me to do this without setting the maxscaledemo
>>> parameter? I would like to view these employer locations from the
>>> overview but identify less than 5 at a time.
>>> Thanks!
>>> Jessica
>>> Let Crystal Reports handle the reporting - Free Crystal Reports 2008 30-Day
>>> trial. Simplify your report design, integration and deployment - and focus on
>>> what you do best, core application coding. Discover what's new with
>>> Crystal Reports now. http://p.sf.net/sfu/bobj-july
>>> Geomoose-users mailing list
>>> Geomoose-users at lists.sourceforge.net
>>> https://lists.sourceforge.net/lists/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20090806/b1c14eab/attachment.html
More information about the Geomoose-users
